Alclad over Tamiya paint, topped with Testor's clear?
mikedealer
Post by mikedealer »
I want to use some alclad chrome, to accent the side grills on the super champ. Currently have Tamiya Primer Under Tamiya Black.
Want to use alclad over the black
http://www.alclad2.com
Then Top it with clearcoat by testors
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFLK4&P=7
will i have to worry about peeling or paint incompatibility?
Y'ernat Al
Has thanked: 7 times
Been thanked: 17 times
Re: Alclad over Tamiya paint, topped with Testor's clear?
Post by Y'ernat Al »
Word has always been that anything over the top of the ALCLAD will dull it back towards silver. ALCLAD would have their own protective clear coat or recommendation if it was possible, so my hunch is that it is not.
The Tamiya black base paint will work. However, because it's a thinner paint (like all the Tamiya paints), it will be a more important to have all the imperfections out of the surface before you start with the Tamiya Black, as any will show in the chrome at the end of the day. The grills do have that fine detail and the Tamiya paint would be good at preserving that.
I used black lacquer Krylon myself as an ALCLAD base, and got a real good polish to it with wet sand=>rubbing compound.
- Brian -
My Gallery
mikedealer
i may try and throw the alclad over the clearcoat, on a black base... gonna try it on some scrap plastic ive been painting also with all the same coats ive been doing on primary body
Vintagemishal
Post by Vintagemishal »
Alclad has a black base that works great. I have used Alclad chrome over their black base and covered it with Createx gloss clear with great results. Looks only slightly less shiny than my chrome plated stuff. If you do not compare side to side, it is hard to tell.
