Removing broken sway bar ball studs?
General info, Q&A.
AndrewSi
Post by AndrewSi »
The ball studs that hold the front sway bar on my RC10 have broken off leaving the threaded part inside the front A arms . Any good tips or tricks to get the pieces inside the A arm out without ruining the arms? Also, provided I can get them out, what is the part number for the ball studs? I have the edinger manual but it lacks all the part numbers for the screws.
Thanks in advance.
Has thanked: 3699 times
Been thanked: 1980 times
Re: Removing broken sway bar ball studs?
AndrewSi wrote:The ball studs that hold the front sway bar on my RC10 have broken off leaving the threaded part inside the front A arms . Any good tips or tricks to get the pieces inside the A arm out without ruining the arms? Also, provided I can get them out, what is the part number for the ball studs? I have the edinger manual but it lacks all the part numbers for the screws.
Thanks in advance.
Dremel with an engraving head. :wink:
Oh, and safety glasses. :wink:
AndrewSi
Post by AndrewSi »
Bump!
Does anyone know the part number for the correct balls studs for the front sway bar on a gold pan?
rctenracer
Been thanked: 81 times
Post by rctenracer »
Dubro 2/56 ball studs will work. I just used parts out of the two listed to make a complete sway bar set up.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD897&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD899&P=7
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
New arms would be easier :wink:
AndrewSi
Post by AndrewSi »
Awesome! Thanks guys. Those ball cups look to be the same aswell. :D
