Sway Bar Question
FeelixX26
Sway Bar Question
Post by FeelixX26 »
hello all. the gold pan i have came with a broken sway bar. it also has andys front a arms that are wider. do i still need to fix a sway bar to the front? looking at the manual for C.E., Team Car and Worlds Car i dont see a sway bar in any of the pictures. so the sway bar is not needed if i run wider a arms?
mike
LowClassCC
Has thanked: 108 times
Been thanked: 171 times
Re: Sway Bar Question
Post by LowClassCC »
sway bar is optional for ether set of arms. some people use them some people don't.
dldiaz
Has thanked: 41 times
Been thanked: 58 times
Post by dldiaz »
I have been searching a while for some information on mounting the front sway bar to an early RC10... without success.
Can anyone tell me part numbers for the following:
1) the small button-head screws that hold the sway bar down
2) the washers associated with these screws
3) the ball stud that threads into the front A-arm, for sway bar attachment
Thanks for any advice on this.
-dldiaz
treehugger
Post by treehugger »
you should find what you need here
Paul
http://www.theshreves.com/rc_stuff/rc10history.htm
dldiaz
Post by dldiaz »
treehugger wrote:you should find what you need here
Paul
Unfortunately not. I did check the manual before posting my question, if you look at figures 137-139 in the early manual, it references the sway bar installation, but, it only says to use the hardware "in the bag" with the sway bar - I do not see that it gives part numbers (nor size specifications) for the screws, washers, or ball stud.
Anyhow, thanks for the reference. :)
-dldiaz
the ball stud is the same as one that is used on the front end, like for instance, on the steering arm, servo saver, or c-hub.
the button head screw is the same as the ones used to hold the motor plate to the rear guard.
the washer i beleive is the same as used behind the nut at the top shock mount.
badattitude
Post by badattitude »
I don't think you can use a sway bar with the Andys arms. There is no place to attatch the sway bar to the arm. Right? :?:
there is if you drill 2 holes. :wink:
Users browsing this forum: No User AvatarTbot [Bot] and 11 guests
