Fresh Stealth Rebuild, here's how
General info, Q&A.
RC104ever
Post by RC104ever »
So I've been looking to rebuild the diff in my stealth as well as replace things like the idler shaft. I went into my LHS which had the parts but the guy couldn't find the diff rings and a couple of the smaller pieces.
I was able to get the 6581 3/32 carbide diff balls, 6570 idler shaft and the 6580 diff gear. The rest, came from the TC3 diff rebuild kit 3926 instead of getting 6573 differential thrust washer and 6575 thrust t nut and 6579 Differential drive rings.
Everything fit perfectly! I already had a B4 topshaft so only thing left if I want it brand new is new bearings.
Thought I'd pass this info along in case you wanted to do this too! I just took the car for a spin and it works great :mrgreen:
- Chris
Lots of cars...so many cars
LTO_Dave
Has thanked: 52 times
Been thanked: 287 times
Re: Fresh Stealth Rebuild, here's how
Post by LTO_Dave »
Thanks for this info! I've seen pics of the TC3 rebuild kit and have always wanted to know if it would work.
RC104ever
Post by RC104ever »
No problem! I forgot to mention that I used the instructions on the AE site to do the rebuild just to be sure I didn't miss anything. Even used the proper AE stealth diff lube and black grease :mrgreen:
- Chris
susko
Post by susko »
Nice
do you have a Link to the ae rebuild manual I cant seem to find it
EDIT:
I think I found it. Did you just look at the team car manual? link
RC104ever
Post by RC104ever »
I think so - but honestly it's pretty straightforward once you take it apart.
- Chris
susko
Post by susko »
Well I know it is a simple design but I am awaiting the arrival of mine in the mail. I just wanted to see what it was like on the inside. The team car manual has some good pics that show the inner workings.
slow_jun
Post by slow_jun »
You can also use the idler gear of a RC10GT ,part number im not sure,but it has been done.
― Confucius
Users browsing this forum: No User AvatarGoogle [Bot] and 2 guests
