Traxxas SRB... Stadium Racing Buggy
SnoopMaxx
Post by SnoopMaxx »
I think it's about time I post my Traxxas build here
I'm working on an unlimited buggy like the ones in LOORS and TORC
build with Traxxas parts instead of just buying a Losi XXX-SCB
I'm calling it the Traxxas SRB after the Vintage SRT I'm using for parts
Have a look at the prototype chassis
It's made of alloy but the finished chassis will be 3mm G-10 fibreglass with 5mm G-10 front and 3mm rear shock towers
And a custom Rollcage
I modelled my cage after the Losi SCB and I did think about getting one, but it looks to narrow
My cage will be around 4" wide
The fibreglass sheets are ready to be cut out
Chassis and tower cut out, only need a bit of sanding
The chassis plates and towers are done
but theses still a few things left, before I can drive it
It's a roller
I handmade a ball-bearing supported bell crank
Does this look familiar :lol:
I need longer front arms mounted with the Pro-Line inline steering,
that means, custom front arms
I want an alloy motor-plate so I need to do a bit of milling on the gearbox
besides, I can't find my original SRT gearbox
Still need to:
Redo the bulkhead
Weld the roll-cage
Sort the electronic
Morten
Morten Max
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Re: Traxxas SRB... Stadium Racing Buggy
Post by klavy69 »
Nice 8) . Been watching these buggys become a little more popular, and then a little more popular, and then a little more popular. Been waiting for the other major manufacturers to jump on this bandwagon. I'm likin your build Morten...keep us posted on it.
Chris K
Post by Chris K »
klavy69 wrote:Nice 8) . Been watching these buggys become a little more popular, and then a little more popular, and then a little more popular. Been waiting for the other major manufacturers to jump on this bandwagon. I'm likin your build Morten...keep us posted on it.
I think that these buggies will be VERY popular - as popular as SC trucks??? Probably not because they're a bit harder to drive and you have the 'exposed wheel thing' which won't appeal to all SC folk...
This build looks really good and I'm anxious to see how it progresses!!!!!!
AND to see if/when Traxxas jumps in with a RTR!
Wherever you go; there you are!
SnoopMaxx
Post by SnoopMaxx »
Thanks guys
This should be easier to drive sins it lags the "parachute" body
And I just ordered the 6069-00 front inline steering hub as well as some other parts for this buggy
Stay tuned :wink:
Morten
Morten Max
SnoopMaxx
Post by SnoopMaxx »
"Small" update
17mm hex
Need to fab a custom shaft , the proline inline hub uses 1/4" bearings and the 17mm hex is 5mm
RPM gear cover and Rustler drive shafts
I made the custom front axle, and the 17mm hex fits perfectly now
but the plastic links have to go bye bye :evil:
I need 3 or 3,5mm turnbuckles with heavy duty rod ends :cool:
Nylon plates and Tie-Rod links mounted
Got the C on the right side and mounted the link in front so the hub doesn't rub
Got my old lathe cross table modified for the drill press
So I can remake the bulkhead
LOL you should see my work table and the parts storage at work :lol: It's SPOTLESS,
My hobby room is a 230 square foot workshop crammed in to an 8'x12' area :oops:
I hate moving
Next ...Rollcage
Morten
Morten Max
SnoopMaxx
Post by SnoopMaxx »
Morten Max
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
Nice custom job but since you're going for scale... I have to be honest: I think those wheels are way too big for the wheelbase.
With the re-re of the fast attack vehicle by tamiya you could get yourself some much closer scale appearance wheels and tires.
SnoopMaxx
Post by SnoopMaxx »
Well scale look and race performance
I do have a set of FAV wheels and sand scorcher tyres, and they are perfect for 1/10th scale, this buggy is closer to 1/8th
I checked the rules for Pro Buggy wheel and overall size
Tyres 35" x 10,5" tyres = 110mm x 33mm
Wheels 17" x 9" = 54mm x 28,5mm
My wheel base is 335mm, like the Slash and Losi xxx-scb
I do think that the Jconcepts J82 front wheels & tyres will look allot better
Do you know of any other 2,2" tyres that are 110mm high with a realistic thread ?
Morten
Morten Max
SnoopMaxx
Post by SnoopMaxx »
welding jig
Morten
Morten Max
SnoopMaxx
Post by SnoopMaxx »
One side done and bolted to the chassis
Morten
Morten Max
SnoopMaxx
Post by SnoopMaxx »
Almost done with the center section
Morten
Morten Max
Jedi Master
Post by Jedi Master »
Coming together nicely!! 8)
Do, or do not! There is no 'try'!
RC; Boats, Buggies, Trucks, Bash's, Racing and of course 'VINTAGE'!
My Ebay Feedback: http://feedback.ebay.co.uk/ws/eBayISAPI.dll?ViewFeedback2&userid=jedimaster768&ftab=AllFeedback
SnoopMaxx
Post by SnoopMaxx »
How's this ?
It's very close to what I want, only need to make the rear section.
And a heap of odds and ends
Morten Max
SnoopMaxx
Post by SnoopMaxx »
What now ?
How do I mount the motor ?
Morten Max
SnoopMaxx
Post by SnoopMaxx »
Alloy motor plate done
The Idler shaft is hollow so I simply screw a bolt in to the plate to hold it in place, you can see where the bolt will be
Morten
Morten Max
Return to “Traxxas Forum”
Users browsing this forum: No User AvatarAmazon [Bot], No User AvatarBing [Bot] and 4 guests
