Corally MMS speed control
- camlchris
- Been thanked: 4 times
Hi: Anybody knows this Corally ESC specification ? What is it max current and constant current output ? What is the lowest possible motor turns can be installed at 7.2Volts ? Anybody tried the 4.8Volt or 3.7volts Lipo ? Then at what motor truns ? Tks for help.
- Been thanked: 100 times
Re: Corally MMS speed control
This Corally MMS I ESC was released 1987 and was the first version of their MMS systems. There were no technical details published beside the fact there was a 8 min. version for 1/12th scale and a 5 min. version for 1/10th scale.
From my knowledge the only difference was the programming of the current limiter. This was not adjustable.
I´m not sure if it´s working with 4 cells as 6 cells were used that time in Europe. Regarding motorlimit you have to think what motors were used in 1987. I think this will be maybe high wind motors also this ESC is very lowprofile with no heatsinks.
5 minute version with heatsink.
Someone ever have seen an 5 minute without the additional heatsink?
http://classicrc.wordpress.com/esc-electronic-speed-control/corally/corally-mms/
- 945 Views
Last post by littleVETTE
- 2420 Views
Last post by dinglem
- 1419 Views
Last post by FlyinGN
- 2349 Views
Last post by Biggs
- 1377 Views
Last post by Racer_X
- 574 Views
Last post by mikedealer
- 1226 Views
- 4417 Views
Last post by BillKrueger
