MG Magnum Motor`s including a ceramic shaft
igbandy
Post by igbandy »
Hi all,
Thought I would share a couple of photo`s of 2 out of my fairly large collection of modified motors.
Not sure if alot of you are familiar with the MG range of motor`s but these where very good in their day. I have 2, one a Magnum Eliminator 12 double and the other is a Magnum 14 double. The 12 double is a bit special and I have never seen another one, it has a ceramic armature shaft instead of the usual steel shaft. In the day it was very difficult to gear this motor with 1700SC`s on anything but the smoothest off road track as it produced alot of power. I have given the comm a much needed skim this evening. Not rebuilt it yet as I am waiting for some new motor shims.
Nice round comm again :D
YZ-10
Re: MG Magnum Motor`s including a ceramic shaft
Post by YZ-10 »
Wow never seen one before, thanks for posting 8)
Has thanked: 356 times
Been thanked: 470 times
Another variation-
sorry for the hyjack
Mad Racer
Post by Mad Racer »
Didn't AYK make these????
I herd they were fragile and snapped at the pinion end of the shaft.
Yes they were AYK- and that is what I have heard about the shaft as well, particularly during pinion installation
igbandy
Post by igbandy »
No problem on the Hijack, infact sometimes it can be a great help.
The MG motor I have is an AYK can. Its good to see that you dont think that I am a lunatic. Most people do when I tell them about this motor.
As for the shaft snapping, I have always been very careful with pinion installation.
CNA75
Post by CNA75 »
Great to see this thread. I have an MG Magnum red dot motor which I bought for my Fox bitd. I'll dig it out and post up a pic...
GJW
Post by GJW »
the mg has very strong magnet's and the ceramic's shaft's have a super 8) factor. :) how does it run?
igbandy
Post by igbandy »
It runs superbly!. I recut the comm, new brushes, new bearings and it still screams.
Right stuck it back on my Shinwa, and with 7.4volts it is doing 31000rpm @3 amps ( I use an adjustable power supply which shows volts and amps pulled)
