RC10 Stealth Transmission - All Aluminum / Ceramic Balls / Bearings
RC10Riley
Post by RC10Riley »
I am setting out to build the highest end RC10 Stealth Transmission available.
This will be entirely aluminum with the case, gears, spur gear all aluminum and ceramic balls and bearings. Vented V2 slipper pads.
Parts List
Case
Diff Gear
Idler Gear
I bought these on Ebay from Dhawk Racing
Balls
Diff
Bearings
Pinion
I bought these from Avid. www.avidrc.com
Spur Gear
I bought these from asap_hobbies on Ebay
Top Shaft
FT V2 Slipper Pads
FT V2 Slipper Vented Hubs
Ider Shaft
Diff bolt/spring
Diff Rings
Screws
I bought these from Team Associated
Total Cost: around $175.00
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Re: RC10 Stealth Transmission - All Aluminum / Ceramic Balls / Bearings
Post by XLR8 »
Sounds awesome but me thinks she's gonna be heavy. :wink:
... but incredibly strong as well. 8)
Are you going with standard AE outdrives?
shodog
Been thanked: 91 times
Post by shodog »
The Dhawk case is nice but there are others out there that have tighter tolerances
jcwrks
Has thanked: 171 times
Been thanked: 393 times
Post by jcwrks »
The high end build would have all Made in USA parts. :mrgreen:
The TX SKUNK
RC10Riley
Post by RC10Riley »
I appreciate the input. I am hoping or willing to sacrifice a bit of weight IF I can get better performance. Questions?
1. Does anyone have any experience running an all aluminum/ceramic stealth?
2. Where can I buy/find aluminum other cases and gears other than Dhawk?
shodog
Post by shodog »
The issue with aluminum cases is that the Dhawk is the only one available. Better ones from golden years, Rogue Elements, and Walt’s are not available anymore and the only way to get one is if you get lucky.
Here is the Walt’s transmission case
Here is the Rogue case
