wheelbase on JRX2
tamiyadan
Been thanked: 6 times
wheelbase on JRX2
Post by tamiyadan »
Synergy
Has thanked: 127 times
Been thanked: 72 times
Re: wheelbase on JRX2
Post by Synergy »
Standard JRX2 I think has a 10.5" wheels base, I'm no expert but I don't think there was ever a LWB version unless you refer to the Proformance conversion? Check through the Losi section you'll find more info on this in recent threads.
Here's my TC Showroom
fredswain
Post by fredswain »
Maybe he is referring to the JRX Pro chassis. The wheelbase is definitely longer. The Pro-SE chassis has 2 rear suspension mounting locations to change the wheelbase as well when using the H arms.
highwayracer
Post by highwayracer »
for the graphite chassis, losi made 2 versions:
original jrx2 short chassis - has a curved edge by the bellcranks
jrx pro / jrxt long chassis - has a stright edge by the bell cranks
losi had 2 designs that were made of the composite material
jr2 - this has the same dimensions and shape as the jrx pro / jrxt chassis
pro se / lxt - this chassis is slightly narrower and there are extra holes drilled towards the rear that allow you to use the shorter set for the car and the longer set for the truck.
Synergy
Post by Synergy »
highwayracer wrote: pro se / lxt - this chassis is slightly narrower and there are extra holes drilled towards the rear that allow you to use the shorter set for the car and the longer set for the truck.
.........and they have no place for five link location.
tamiyadan
Post by tamiyadan »
Return to “Losi Forum”
