Original Gold Shock internal retaining clip size
Does anyone know the size of the retaining clips for the original gold shocks? I'm trying to order some from McMaster-Carr.
- littleVETTE
- Has thanked: 6 times
- Been thanked: 10 times
Re: Original Gold Shock internal retaining clip size
I'm sorry I did not explain better. I'm talking about the internal retaining clip on the outside of the oldest gold shocks that holds the o-rings in place.
- littleVETTE
- Regular Member
I'm only reviving this thread to make sure nobody searching for this retaining ring orders the clip linked above, because it is incorrect. 5/16" is the largest diameter that will fit in the bottom load shocks, but I'd probably go with 1/4" if I was to buy another bag.
- Has thanked: 1243 times
- Been thanked: 639 times
I can report that 1/4" snap ring do not fit at all. They aren't even close to fitting.GorillaParts wrote: ↑Thu Feb 28, 2019 11:32 am I'm only reviving this thread to make sure nobody searching for this retaining ring orders the clip linked above, because it is incorrect. 5/16" is the largest diameter that will fit in the bottom load shocks, but I'd probably go with 1/4" if I was to buy another bag.
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
The snap rings from the Traxxas 2362 rebuild kit fit.
Several of the plastics can be used as well, if you ream the ID from 3mm to 1/8". The bottom cover is particularly useful, as the originals tend to get damaged.
Are the retaining rings in the 6 gear the same size as the shocks rings?juicedcoupe wrote: ↑Sun Sep 26, 2021 7:47 pm The snap rings from the Traxxas 2362 rebuild kit fit.
- juicedcoupe
No. They are larger.JosephS wrote: ↑Mon Sep 27, 2021 12:01 amAre the retaining rings in the 6 gear the same size as the shocks rings?juicedcoupe wrote: ↑Sun Sep 26, 2021 7:47 pm The snap rings from the Traxxas 2362 rebuild kit fit.
I believe that the outdrives use a 3/8" clip. They retain a 5/16" flanged bearing, having roughly a 3/8" OD.
Oh yeah, concerning the Traxxas clips. I believe that they are metric, slightly larger than those on the bottom load shocks. They do fit but are notably harder to install and remove.
- 1895 Views
Last post by BWX
- 396 Views
Last post by kenooze
- 2176 Views
- 1306 Views
Last post by jcwrks
- 2488 Views
Last post by naushad
- 610 Views
Last post by a01butal
- 2692 Views
Last post by juicedcoupe
- 28 Replies
- 8893 Views
Last post by delsami
