a "sandwiched" chassis?
TZona
Post by TZona »
black top and bottom white center
ROH73
Been thanked: 23 times
Re: a "sandwiched" chassis?
Post by ROH73 »
It's likely a foam core between two sheets of carbon fiber; kind of a budget graphite chassis from BITD.
Lowgear
Has thanked: 121 times
Been thanked: 792 times
Post by Lowgear »
Foam chassis huh? Throw some paddles on it, and drive that bad boy in the pool! :lol:
esaresky75
Post by esaresky75 »
BITD?
Burn more coal - UnderGroundMiners.com
ROH73
Post by ROH73 »
back in the day
tucker330
Post by tucker330 »
In the 80's my first "graphite" chassis was a plastic bottom, foam center, with a thin sheat of carbon fiber for the top.
ROH73
Post by ROH73 »
There were some crazy variations available. One had a plywood type core with carbon fiber on the top and bottom. I bought an Optima a couple of years ago with one of those on it. The chassis flexes so much, regular G-10 fiberglass would have been better and cheaper. But, hey, it was 2/3 graphite, and that meant a lot in the 80s :D .
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
It's not foam.
Graphite is a weave of carbon fibers held in place by resin (epoxy), G10 is the same resin but with glassfiber. The center is G10 and since it use the same resin the bonding between the glassfiber and carbon fiber layers is very good.
Losi, composite craft and others all used this technique to produce higly stiff yet less costly chassis.
ROH73
Post by ROH73 »
There are both glass fiber core chassis and foam core chassis. The foam version is thicker and the center section is very white and very noticeable. In this case, I would suspect it's a foam core chassis. The glass fiber version doesn't stand out that much.
TZona
Post by TZona »
i think it was pretty white, i'll snap a pic and post
TZona
Post by TZona »
Uploaded with ImageShack.us
matching towers front and rear, rear has "a touch of class" look like hot trick stuff. ring any bells?
Mr. ED
Post by Mr. ED »
That does look like a thicker core than what I've seen. How hard is that foam? I suppose it's softer than fiberglass ... kind of seems not-the-best choice for countersunk screws.
ROH73
Post by ROH73 »
Yep, that's a foam core. I don't know who made it. The foam is pretty stiff and yes, you had to be careful with the countersunk screws.
raceco
BigPun76
Post by BigPun76 »
My TQ10 has a similar chassis. I thought it was foam too when I first got the thing. Haven't looked at it in ages; I'll have to dig it out when I go back to my parent's house. I do remember the CF "splinters" I always had to dig out of my hands though! No fun! :lol:
Users browsing this forum: No User AvatarDotNetDotCom.org [Bot] and 8 guests
