Tracking down something for a JRX2
I'm restoring a JRX2 and for the life of me I cannot find an original front shock collar (bottom of shock #87 from manual) for this car. Can anyone help me out?
My Little Collection is Here
Re: Tracking down something for a JRX2
are they different from those used on the newer cars, such as P/N A5079, A5023, etc.?
That I do not know... if someone could confirm this it might make the search a little easier??
pictures for reference can be found on these pages
http://www.losipartshouse.com/servlet/the-21446/LOSA5079-Shock-Ends-%26/Detail
http://www.losipartshouse.com/servlet/the-21413/LOSA5023-Shock-Spring-Clamps/Detail
wow.. thanks!!
So these are the same as used in the original JRX2? Looks like the newer top clamp is thicker??
I can't say if they are the same, but you should be able to use the pictures and visually at least tell if they are close.
The A5023 part is correct for a JrxPro and SE variant; it's entirely possible that the bottom spring cup/collar is the same for your Jrx2.
bottom cups are the same form, but not sure if the plastic color changed. been awhile since I looked.
the spring collars are a new improved version, wider, and stronger. the original ones are very weak, as you probably already know.
- mrlexan
- Been thanked: 12 times
I am sure you are a stand up guy, but careful... you need to go through the motions of getting BST access to post wanted threads. Info is fine, but please don't post want thread for parts. Review the following and you'll be fine. Questions, let any of us know. Thanks.
http://www.rc10talk.com/viewtopic.php?f=52&t=909
jay
jay
www.gojammedia.com
www.gojammedia.com
Understood. I'll work on getting access to the BST section...
To re-phrase this and get to the point, my question is: Is the original JRX2 front spring cup the same part as the one linked above that is still manufactured?
- bearrickster
No they were thinner these are the replacements because the jrx2 ones were junk they brake easybreck wrote:Understood. I'll work on getting access to the BST section...
similar and interchangeable, but not the samebreck wrote: Is the original JRX2 front spring cup the same part as the one linked above that is still manufactured?
see post #2 here for a comparison:
http://www.rc10talk.com/viewtopic.php?f=27&t=3171
- mrlexan
Thanks for understanding (and not flying off the handle, some have in the past).breck wrote:Understood. I'll work on getting access to the BST section...
www.gojammedia.com
www.gojammedia.com
breck wrote:I'm restoring a JRX2 and for the life of me I cannot find an original front shock collar (bottom of shock #87 from manual) for this car. Can anyone help me out?
PM and I'll see what I can scrounge in my losi parts bin. Thanks!
- 2236 Views
Last post by Oozzee
- 3980 Views
Last post by DerbyDan
- 1457 Views
Last post by bearrickster
- 30 Replies
- 3515 Views
- 1335 Views
Last post by Synergy
- 1260 Views
- 1045 Views
Last post by GJW
- 53 Replies
- 4281 Views
