KO PROPO Servo
KO PROPO Servo
Does anyone know of a faster servo than the new KO? Its speed is 0.07 sec. I'm trying to get as close to the throttle response in my rc8, as my rc8e has. any suggestions?
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: KO PROPO Servo
Absolutely useless in 8th buggy by the way...
- YZ-10
Re: KO PROPO Servo
Fastest servo KO have made was a discontinued 7.2v one PS-2015 (0.05s think it was) but being 7.2v is no use in a 1/8th buggy anyway, I don't know of any as fast/faster than that and certainly not 6v ones
- Lonestar
Re: KO PROPO Servo
bothcraigc8791 wrote:Wait the servo is useless in 1/8 buggy, or your knowlege is?
all one does with a sub-0.1s/60deg for steering is turn the wheels way faster than the tires can generate grip. Check what the top guns run... torquey, sure, but not stupid fast. For throttle there's two schools, those that say that too fast is not good because the air flow becomes turbulent and hence doesn't fill the chamber as it should, and others that say that "it just works".
do as you please, really
Paul
Re: KO PROPO Servo
Go with the Savox 1267SG with lipo 7.4v....good speed and torque (way cheaper than KO). More than you will need for most 1/8 buggy applications....plus you need the torque to hold a heavy 1/8 buggy through the turns, servo speed is secondary.
- Bimdapogs
Re: KO PROPO Servo
I'll assume the RC8 is Nitro. So you want your nitro buggy to be as responsive as your LiPo powered buggy?craigc8791 wrote:Does anyone know of a faster servo than the new ko? Its speed is 0.07 sec, Im trying to get as close to the throttle response in my rc8, as my rc8e has. any suggestions?
The servo is not the only factor on throttle response. If you're already using that as your throttle servo, you should start looking at your engine setup. How you have it tuned...
That servo looks awesome, BTW. I love their 2413s and this is the first time I found out about this new tech from KO. I don't see myself using it, but it seems awesome.
- 1155 Views
Last post by eco8gator
- 1402 Views
Last post by rcpitwork
- 1505 Views
Last post by Asso_man!
- 906 Views
Last post by SmallScaleSmitty
- 1316 Views
Last post by Mad Racer
- 1093 Views
Last post by REMJ666
- 622 Views
Last post by Dangeruss
- 2163 Views
