Need Composite craft part #
ericsp2
Post by ericsp2 »
I need the part number for the bouble deck chassis from composite craft if anyone knows it. thanks its for my black tub stealth buggy by the way.
a01butal
Has thanked: 34 times
Been thanked: 40 times
Re: Need Composite craft part #
Post by a01butal »
Are you talking about the upper deck for the world's version or the shorter deck that stops just before the front bulkhead?
This is all very interesting!
shodog
Been thanked: 91 times
Post by shodog »
There were a few different versions. I've seen a double deck chassis with battery slots and a double deck without. There was also a double deck chassis with a different shape than the two others. Then there was the worlds version that was for the special RPM arms and mounts
ericsp2
Post by ericsp2 »
well i have a stock black pan stealth car that i want to convert to a double deck chassis so im not sure which one i need.
a01butal
Post by a01butal »
I was under the assumption that CC upper decks were made to go along with CC chassis plates. Could be there was one made but don't think I ever saw one on a aluminum tub so far.
ericsp2 wrote:well i have a stock black pan stealth car that i want to convert to a double deck chassis so im not sure which one i need.
then you'd be looking for the "team car" composite craft upper deck.
the more i think about it, your not gonna be able to use it on a tub chassis because of the way it's designed to mount to the rear bulkhead. as a matter of fact, a world top plate probably wouldn't work, either.
shodog
Post by shodog »
I can't imagine you would need to strengthen an aluminum pan chassis.
i'm starting to think he want's a complete double deck chassis. when he said he wanted to convert his car, i was thinking he just wanted to add an upper deck to his existing tub. he wants to swap out the chassis completely, but didn't know which one to use.
so that being said, since you have a stock rc10, you'll want the "team car" chassis kit. the part number for the chassis is #10001. i don't know what the upper deck part number is though. i can't find my old header card.
a01butal
Post by a01butal »
That's the one I have and unfortunately the sticker with the part number has fallen off the header tag for the upper deck, the standoffs part # is 10030.
ericsp2
Post by ericsp2 »
sorry i should have been clear. i dont want the aluminum tub anymore. i want to convert it to the cc chassis and upper deck. i need the part # for the whole kitt, sorry
ericsp2
Post by ericsp2 »
I can use a worlds one too.. i have the conversion parts as well. thanks guys.
ericsp2
Post by ericsp2 »
heck id even go for a rc10t chassis setup
ericsp2
Post by ericsp2 »
anyone?
shodog
Post by shodog »
I have a nib chassis but its slotted, not double deck and drilled for 6 gear
ericsp2
Post by ericsp2 »
Dang all mine have the stealth. :cry:
