Runner Yokomo Build
slapshot1979
Runner Yokomo Build
Post by slapshot1979 »
Just picked up a yokomo, and I am planning on building it up as a runner to use with our little vintage group we have up here. I have some questions as to what I actually have as i seem to see a few variations on the YZ10. My plan is too build a new chassis/top brace from 2-3mm aluminum to bulletproof and to make room for 2s pack instead of the hump pack.
The trackwidth is even but with the wheeladapters the front wheel would hit the rod ends so do I install the wider adapters? (I have them).
And something leads me to believe the front a-arms are too wide was this a upgrade ppl did??
Also a lillte confused on the different belts, pulleys, parts #s etc
So if you guys dont mind have a look at the pictures and let me know what you see/thinkImage
a01butal
Has thanked: 34 times
Been thanked: 40 times
Re: new to Yokomo
Post by a01butal »
93 Works, I believe.
This is all very interesting!
GJW
Re: new to Yokomo
Post by GJW »
actually it's a 91 with 93 rear shock tower/torque brace/ti turnbuckle's, that front tower looks cool home made perhaps. good find mate :)
Justjoe
Re: new to Yokomo
Post by Justjoe »
looks like a 91 chassis with 93 drive train and a YR4 rear tower on the front, with yokomo front shocks and associated rears. The front looks like you might have the wrong wheel adapters on the axles...I dont think the wheels should be that close to the tie rod ends. The chassis top brace is listed on ebay right now, so are a few other parts.
USAF Retired
870C, Works 91, YR4-M2 Pro, RC10 Graphite, RC10 Carbon fiber tub
Old Skool RC10 Gold pan, RC10DS, Traxxas REVO
a01butal
Re: new to Yokomo
Post by a01butal »
Kind of looks like a 93 with the wrong chassis underneath to me. :lol: :mrgreen:
Justjoe
Re: new to Yokomo
Post by Justjoe »
I was trying to build a 93 works but the chassis is nearly impossible to find...LOL. So I have ended up with about the same setup you have there. Everything has been NIP with the exception of a used works 91 chassis. The parts are out there you just have to look for them for a while...Or get with Aaron or Al. :D
USAF Retired
GJW
Re: new to Yokomo
Post by GJW »
93 works had a factory TCS, 3mm belt's, and different ti turnbuckle's(anodised) steering brace off the front bulkhead and a steering rack set-up, this buggy has none of that and looks to have 2mm fine pitch belts :)
slapshot1979
Re: new to Yokomo
So how does the parts # system work for these cars?? the front belt reads zc-653 rear 491j is this the number I look for or is there a corisponding part #?? how about gears??
So as the kids say this is a HYBRID lol ..heinz57 which is ok by me.
I dont like either shocks so I look for something more modern.
Is there supposed to be a belt tensioner pulley??
Thanks guys you rock.
SMOKE-DOG
Re: new to Yokomo
Post by SMOKE-DOG »
It actually looks like a YR-4 conversion to buggy.
GJW
Re: new to Yokomo
Post by GJW »
here is a pic of a 92, basically the same car :)
slapshot1979
Re: new to Yokomo
Had sometime today did some mockup where I want the battery and such and needed the chassis to have a little different shape so cut out the new one and installed keep in mind no filing or polishing has been done yet and still in the early stages, the top brace needs to go on a diet and the bottom possibly too.Image
fakiee
Re: Runner Yokomo Build
Post by fakiee »
Where can I find those gold ball ends?
GJW
Post by GJW »
RC10Eh
Post by RC10Eh »
How about a 8 x 15 sheet of 1/8 G10 ( Original Parma ) to help you along ? And maybe the loan of my 870c for inspiration ? Hook you up Friday 8)
fakiee
Post by fakiee »
Thanks! They look great - will pick up a set! would still like to get the OGs
Return to “Yokomo Forum”
