MIP changebox transmission for RC10
m_vice
Post by m_vice »
Haven't seen a lot of these around but I ended up with one.
I got this on my later purchase, got a T2 and it came with a MIP tranny. When I opened the case, it had the incorrect diff in it.
Long story short I found the MIP diff on the T2 tranny and I discovered the T2, GT, B4 and T4 tranny diffs has the same teeth count as the old MIP changebox tranny.
Anyone knows how to get this old tranny case whiter? Peroxide?
I think you can use the newer diff on the old MIP if you sand it down and make it thinner.
I don't have any manuals or any more knowledge on this so any more info on this is welcome.
Gear Ratio = 2.61
:D
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Re: MIP changebox transmission for RC10
Post by adam lancia »
You just had to ask, I found that out a little while ago. You're right about needing to sand down the Associated diff gear, it's wider than the one from MIP. It's not much though, may be easier to clearance the inside of the case if you're going to be constantly using the Associated diff gears...
m_vice
Post by m_vice »
Thanks, the only reason I know if because it received this.
Thanks for the confirmation.
:D
ThomasH
Post by ThomasH »
I was looking at one of these the other day on ebay. I was thinking of giving it a try but could not find rebuild parts. Would be good if you could get the newer diff to fit. I wonder if there are any idler gears that could be used as well?
Strange to see bushings in that box. I would have thought if some one had paid so much to get a new box they would have got bearings too.
m_vice
Post by m_vice »
I am looking for a manual if anyone has one.
I rebuilt the diff with new parts and I cant get it to be smooth like the regular diff. I am wandering if this is normal or if I am missing a spacer or something.
murphy3428
Post by murphy3428 »
M-VICE if you go to my blog you will find the build sheet for this trans along with a list of parts needed hope this helps.Regards,Chris http://acmracing-vintagerc.blogspot.com/search/label/TIPS%20%2F%20MANUALS%20%2F%20OLD%20ADDS
m_vice
Post by m_vice »
Is this the only paper in the bag?
murphy3428
Yes that was it
m_vice
Post by m_vice »
murphy3428 wrote:Yes that was it
Thanks, did you build yours yet?
murphy3428
I built that trans a roughly 2 years ago it sat on a shelf for awhile and then was installed in my hot http://www.rc10talk.com/viewtopic.php?f=35&t=9574&start=15trick oval
murphy3428
You may be able to use some parts from this trans the case looks fairly close the MIP here is the link http://www.acechassisco.com/products/products_motor.html
m_vice
Post by m_vice »
Ok, I decided to show the built of this tranny after cleaning.
The transmission case was defective when I got it; it was missing a plastic piece (it is like a spacer but it had thread to screw the motor plate to the tranny box from the motor plate side). I made an aluminum spacer and got a longer screw so it grabs from the plastid tranny box.
Nice old stealth slipper clutch.
Now to deciding on what project to use it.
The motor plate is a temp motor plate until I decide on the car this is going to go in.
:D
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
Since the MIP box uses a standard top shaft, you could swap over to B4/T4 slipper parts really easily (as compared to the RPM box).
Users browsing this forum: No User AvatarAmazon [Bot] and 8 guests
