MIP changebox information
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
So wandering the swapmeet this weekend, happened upon a neon yellow MIP changebox...but no diff gear.
Did it use the standard Stealth gear (like RPM) or a MIP specific unit (I did see a picture of a NIP one, it had a diff gear in there...so not too confident about the purchase now).
- Has thanked: 36 times
- Been thanked: 1320 times
Re: MIP changebox information
the mip change box used a larger mip diff and idler gear, with a stock associated topshaft, to gain the 2.61 ratio.
the idlers are fairly easy to find. they pop up on the bay quite often. i can't say that i've ever seen a diff gear for sale, though. but i'd bet if you posted something in the wanted forum, someone here has one they don't need.JK Racing wrote:The search is on...![]()
- JK Racing
I gotcha...I have to try on my own for a quick minute first!!
- Has thanked: 7 times
- Been thanked: 42 times
JK, the MIP diff gears are the same tooth count as the current B4/T4 diff gears, just narrower. I'm sure someone here has one they can measure (my stuff is at my parents house). IIRC, it's not a whole lot, just needs a light skim on either side.
- JK Racing
I will try the diff gear trick...
NIP one pictured in this thread (courtesy Scr8p).
http://www.rc10talk.com/viewtopic.php?f=36&t=18071
Did they ever come in neon yellow? If it was dyed, they did an excellent job!
- 2857 Views
Last post by JK Racing
- 633 Views
Last post by Mr. ED
- 25 Replies
- 2155 Views
- 23 Replies
- 4319 Views
Last post by klavy69
- 1987 Views
Last post by Dadio
- 894 Views
Last post by Dadio
- 1133 Views
Last post by minichamps11
- 1322 Views
Last post by Phin
