Novak 4 specs
esaresky75
Novak 4 specs
Post by esaresky75 »
I have a Novak 4 ESC, the manual states the max current is 176 amps but doesn't give a recommended max motor turn. Recommendations? Also, the brake transistor is bad, before I start to Google the number on it, any known source? I usually buy from Digikey.
Burn more coal - UnderGroundMiners.com
RC10Eh
Re: Novak 4 specs
Post by RC10Eh »
esaresky75
Re: Novak 4 specs
RC10Eh wrote:simple search of the forum produced this .....
http://www.rc10talk.com/viewtopic.php?f=40&t=10292&hilit=novak+t4+manual
Thanks, but that post is about a T4, mine is a the original "4". Not sure if only the TEMPFETS are the only thing different.
GJW
Re: Novak 4 specs
Post by GJW »
i opened this up for you to compare info :)
RC10Eh
Re: Novak 4 specs
Post by RC10Eh »
Thanks Gary , I hope you put the staples back in the same holes lol . Like ROH73 stated in the thread , Novak as far as i know did not rate SC in that manor .
GJW
Re: Novak 4 specs
Post by GJW »
yep! i will one day have to get a stapler first :P just thought he might have a t4 manual and wanted a look at the 1 & 4 manual, didnt think there would be motor turn section :wink:
esaresky75
Re: Novak 4 specs
Wow! That is something. How long have that? Thank you, so there is a difference. The 4 is rated for 120A and the T4 is 176, a decent difference.
