Need some Ultima gear specs
- Been thanked: 325 times
Can someone here with Ultima & Turbo Ultima parts or experience provide me the following details? If you knew the stock gear ratio(s), that would be great too.
-Final pinion gear #teeth
-Counter gear #teeth
-Differential gear #teeth
Thanks, much appreciated!
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
Re: Need some Ultima gear specs
Ok, this is from my horrible memory. I think the final pinion has 19 teeth and the diff gear has 58. All .8 module. I don't remember the number of teeth for the counter gear. The spur gear has 44 teeth though.
- transamman908
- Been thanked: 5 times
Stock Ultima gears:
Final pinion=19t
Counter gear=28t
Diff gear=37
Center gear=41t
Final pinion=19t
Counter gear=28t
Diff gear=37
Center gear=41t
- RichieRich
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Mark, I don't get why you need to ask: they are identical to your optima gears.
- Hcp22
- Has thanked: 33 times
- Been thanked: 22 times
Isn’t there a formula that you can use when you calculate the gear ratio?
- Mr. ED
ofcourse:
internal ratio = (diff/inner gear)x(outer gear/cluster gear)
final ratio = internal ratio x (spur/pinion)
- Hcp22
Thanks Mr. ED! Sins Optima and Ulima have the same gearbox layout as the Scorpion. And I need to calculate the Scorpion gear ratio so I don’t over gear and kill my brand new 2X17 motor at our indoor vintage meet.Mr. ED wrote:ofcourse:
- Has thanked: 170 times
- Been thanked: 23 times
Coelacanth wrote:Can someone here with Ultima & Turbo Ultima parts or experience provide me the following details? If you knew the stock gear ratio(s), that would be great too.
3.0 is the gear ratio for the Ultima and Optima
- Mr. ED
3.03 actually
www.rc10talk.com/viewtopic.php?f=40&t=17667&p=172084
this topic has a list with others also
- 770 Views
- 2130 Views
Last post by Mr. ED
- 2390 Views
Last post by Mr. ED
- 25 Replies
- 2542 Views
Last post by Mr. ED
- 1294 Views
Last post by esaresky75
- 641 Views
Last post by civilguy
- 963 Views
Last post by Tadracket
- 2744 Views
Last post by Drusky
Users browsing this forum: Google Adsense [Bot],
Scottzone,
Swath and 5 guests
