looking for a modern steering fix
I got an A chassis RC10 as an xmas present, cleaned it up, got some new wheels and tires for it then promptly crashed it. Which was awesome.
Problem is I broke the bell crank. Since I'm sure this is the first in a long line of busted parts I'll be replacing I was wanting to find out if there is any kind of modern replacement for the bell crank.
If not I'll be fabbing something up, but for now I'd like to find something that's more or less considered off the shelf.
Sorry if this has been asked before, I've done some searching and couldn't find a solid answer.
- Synergy
- Has thanked: 127 times
- Been thanked: 72 times
Re: New guy with a question
Welcome to the forum, I'm not sure but if you have a look through this thread there might be some ideas for you:-
http://www.rc10talk.com/viewtopic.php?f=38&t=10403
Here's my TC Showroom
here is a thread more dedicated to your topic, although be sure to go through that first link Synergy gave you, it shows how to modernize the car to use more commonly available parts for the rest of the car.
http://www.rc10talk.com/viewtopic.php?f=38&t=16582&hilit=traxxas
throwing out a suggestion here, (and not intending to be a jerk, please take no offense), but a more specific subject line would help to search this thread in the future, this comes up occasionally and I don't think there is a good solid thread about this. changing you subject like to something like 'modern steering fix' or something like that would be helpful moving forward.
glad to see you joined, enjoy the forums, but be careful. this place seems to become a source of addiction to the hobby
Re: looking for a modern steering fix
Awesome. Thank you for the input. I went ahead and changed the thread title as well.
The worlds steering can be found often enough on the bay, why not use it? -Jeff
total cost of the traxxas stuff wouldn't be able to buy part of one of the worlds arms at the normal going rate. the plastic parts are around 3-5 bucks. tubing, another couple. You would use bearings in either case, but this setup uses 3/16 x 5/16 bearings which most have floating around from all the old gold tub jelly bean wheels.
so it's simply a matter of cost and availability. not that it happens often, but if you happen to break the plastic parts, they are probably hanging on the rack at most hobby shops.
That's exactly what I'm looking for. Something that I can go to a hobby store locally and find hanging on a shelf. I really freaking hate waiting for parts that I've ordered online. The other thing I'm looking for is something that will require as little machine work as possible. Though I have access to things like a drill press, band saws, etc, it would be awesome to find something that would work without having to modify parts.jwscab wrote: if you happen to break the plastic parts, they are probably hanging on the rack at most hobby shops.
From the links I've decided I'm going to give these parts a shot:
Traxxas bellcrank set part number 2543
k&s 3/16" aluminum tube part number 5104
3/16" x 5/16" bearings
I'll report back with what I come up with.
Well I finally got around to getting parts and installing them. I'm happy to say that with about 5 minutes of work with a hand held drill the setup I listed fell right into place.
The only thing I had too was reem the aluminum shaft just a bit with a 3/16 drill bit. After that they slipped right onto the stock bellcrank screws. Everything elsewent right on without any modification or headache.
- 1401 Views
Last post by RC10th
- 2027 Views
- 885 Views
Last post by Johanp
- 1057 Views
Last post by Bent
- 1219 Views
Last post by RC104ever
- 45 Replies
- 4557 Views
Last post by stephenianjames
- 2412 Views
Last post by longboardnj
- 1083 Views
