Gear tooth face width doesn't match...is this OK??
- Regular Member
Just purchased a pinion gear from ebay. it was advertised as a RC10T3 gear...but low and behold...its not. The face width is about 1.5mm shorter than stock. I'm concerned the short face width will wear the mating PLASTIC spur gear unevenly. The stock pinion face width matches the width of the spur gear.
I contacted the seller and he states that he runs this gear all the time with no problem. I'll admit, I've just got back into the hobby after 19 year hiatus, so I'm kind of green...but this dosn't make sense from a gear design perspective. If the pinion and spur were made of the same material then I might agree that the effective face width can be less than the actual face width, but since the spur gear is plastic, the required effective face width may be the entire width of the gear teeth...
I need some real world experience from you guys...
Any thoughts?
Any thoughts?
Re: Gear tooth face width doesn't match...is this OK??
i've never had a problem running like that.
as long as the mesh is good and the pitch is correct you should be fine.
- Regular Member
Thanks guys. I would've thought the harder pinion would eventually wear a square shaped notch in the softer plastic spur gear...I guess if you've never had this problem I shouldn't worry
just make sure you set the gear mesh right, it shouldn't be tight. a good way to set the mesh is to put a peice of paper between the two gears. that spacing is just about perfect.
- 1858 Views
Last post by Mindwarp
- 652 Views
Last post by DMAT
- 513 Views
Last post by Chewbacca
- 1806 Views
Last post by drbelleville
- 3116 Views
- 31 Replies
- 5479 Views
Last post by Jay Dub
- 1162 Views
Last post by firebird1999us
- 716 Views
Last post by HWS_Losi
