Memory Jog
Memory Jog
Can someone tell me how to curl your servo wire, I have it done on my b4, but I dont remeber how i did it.
- lowrydesign
- Has thanked: 11 times
- Been thanked: 22 times
- Eau Rouge
- Been thanked: 5 times
Re: Memory Jog
All ya had to do was ask!
Take a small screwdriver (I prefer a pinion wrench driver), and tightly wrap the wire from start to finish, keeping it tight as you go. the smaller the tool you wrap it around, the tighter the coil.
To straighten a coiled wire, take the same tool on the reverse side and pinch the wire between your thumb and the tool, and pull, like you are starting a lawn mower. You are essentially reversing the curl in the opposite direction.
Be careful not to pull the wire from the source connection, as you could possibly pull it out of the circuit board it is connected to.
Good luck,
dc
Good luck,
dc
- 622 Views
Last post by Phin
- 38 Replies
- 4232 Views
Last post by RC10th
- 2496 Views
Last post by Rustbucket
- 707 Views
Last post by adam lancia
- 3674 Views
Last post by Mr. ED
- 57 Replies
- 7371 Views
Last post by madweazl
- 1472 Views
Last post by urban hype
- 19 Replies
- 3326 Views
Last post by hondaman
Users browsing this forum: Google Adsense [Bot],
Yandex [Bot] and 5 guests
