Vintage SRB parts
Vintage SRB parts
hi all, here's some vintage SRB stuff i found at my local hobby shop, enjoy
cheers Bullfrog
cheers Bullfrog
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
Re: Vintage SRB parts
Good stuff! Caster blocks even! Don't see those much! Can you please shoot another photo with the entire instruction text visible! -Brian
I made a set of Kydex wedges to serve that purpose on my runner. That is a un-sung modification that really changes handling. Very good to play with if you are into the srb. Technically, I've convinced myself that little reduction in caster is best for most running, tilting the front end top-forward, so the suspension action is a hair closer to vertical than stock. Technically loose a little steering but in reality takes some bump steer and a lot of the bounce out. The front wheels spend more time on the ground, which then helps steering and control on a lot of surfaces, IMO. (My experience is on hard US-Open type golf coarse grass).
- airdreams1
Id love a set of the nerf bars like the ones in the last 2 pics of first post) if you ever want to part with a set.
- Been thanked: 7 times
I have seen people using the RC12E radio plate to replace the SRB radio box, it worked well
- 1012 Views
Last post by terry.sc
- 3741 Views
Last post by tiger1
- 1281 Views
- 1123 Views
Last post by terex
- 1054 Views
- 2970 Views
Last post by carloco8
- 1801 Views
Last post by Jeep-Power
- 1234 Views
Last post by jcwrks
