double checking
General info, Q&A.
sneako43
double checking
Post by sneako43 »
Has anyone used the RPM One Piece Bellcrank Center Link? Can it be used with the RC10/T stock steering setups or only with the RPM setup? Nothing in the description says one way or the other so I wanted to double check with the experts!
Thanks.
SC10 -- FT B4.1
civilguy
Has thanked: 5 times
Been thanked: 14 times
Re: double checking
Post by civilguy »
I use one with my MIP bellcrank setup, but it's been so long. I'm guessing mine is a buggy centerlink... did RPM make more than one? Mine measures approx. 1.5".
Jeff
bully
Been thanked: 6 times
Re: double checking
Post by bully »
Fits std truck,buggy 4sure and the 2 aftermarket steering racks i have houge type i think.
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Re: double checking
Post by RichieRich »
I use them for all my builds. AE also made one that Tower still sells.
sneako43
Re: double checking
Post by sneako43 »
Thanks to each of you.
SC10 -- FT B4.1
shodog
Been thanked: 91 times
Re: double checking
Post by shodog »
And if you needed a third reply confiming it works then here is mine. I used this link on quite a few builds including my 10T
