Checking Tempeture without a thermometer
soniccj5
Post by soniccj5 »
I just took my RC-10(with a b3 stealth) for a run at the park for the first time with the Novak BL 10.5 . I drove in the volleyball area, but spent most of my time on very short cut grass. The motor stayed warm to the touch for the full battery(15 minutes). The gearing is 83/21 and my tranny is 2.40 so if my math is correct, I have a FDR of 9.48.
I am going to try a 24 pinion, but worried about over heating my motor without the use of a good temperature gauge.
Should I invest in a good gauge, or keep using the old school method?
Thanks,
ED
LowClassCC
Has thanked: 108 times
Been thanked: 171 times
Re: Checking Tempeture without a thermometer
Post by LowClassCC »
invest in a gauge and change pinion sizes by 1-2 teeth at a time max. i wouldn't jump from a 21-24.
vintage racer
Post by vintage racer »
Last time I raced at my local club some guys were using some stick on tags that changed colour or something to tell you the different temps.Not as accurate as a gun but they seemed happy with the way they worked and I bet they are cheap.
fastang
Post by fastang »
Temp guns are cheap enough now days I would just get one.
rctenracer
Been thanked: 81 times
Post by rctenracer »
SteveK
Post by SteveK »
Are BL motors that sensitive to temperature? How hot do they normally get?
This reminds me of two stories/jokes:
- Some guys had a home-built supercomputer in their apartment, and they kept track of the CPU temperature with a meat thermometer; when it went to 'pork' it was getting too hot.
- Comedian Daved Brenner told a joke about a guy suing a hotel because he was taking a bath and burned his 'boys'; "who checks the water temperature like that?"
Jeep-Power
Has thanked: 56 times
Been thanked: 52 times
Post by Jeep-Power »
the manual on the Traxxas 3500kv motor says that you should be able to hold your finger on the motor for atleast 2 seconds. Hows that for a rule-of-thumb. ;)
TallPeter ~ Hopeless Gearhead
Early Goldpans 'Fun Buggy' RC10C B44.3 RC8B3.1 RC12l 10LS Pro10
Jeep-Power wrote:the manual on the Traxxas 3500kv motor says that you should be able to hold your finger on the motor for atleast 2 seconds. Hows that for a rule-of-thumb. ;)
well........ it's better than having to stick your tongue on it for 2 seconds. :mrgreen:
Jeep-Power
scr8p wrote: well........ it's better than having to stick your tongue on it for 2 seconds. :mrgreen:
LOL-- nice! :wink:
treehugger
Post by treehugger »
after spending 20 years in construction i can pull stuff out of the stove with no glove so i will splurge on the temp gun i think
soniccj5
Post by soniccj5 »
I guess 24$ is a small price to protect 150$.
Thanks,
ED
SteveK
Post by SteveK »
That's part of the trick behind those guys who walk across hot coals for tribal rituals (or now for shows for tourists). Walking around barefoot more often is certainly going to toughen the skin on your feet. I can barely walk on my driveway without shoes on.
