JRX2 shock questions
66intheSky
Post by 66intheSky »
Anybody know what new Losi part #'s will fit original JRX2 shocks?
I want to replace the front & rear shock shafts, cartridges, and collars.
I think they are pretty much the same shocks as on the
1/10 Dessert Truck, but I'm not positive. Any info would
help to fix these leaky old SOB's. Thanks.
BTW I wish I could find the conversion that lets you use the original RC10 o-rings and washers. Much better setup IMHO.
JK Racing
Has thanked: 129 times
Been thanked: 242 times
Re: JRX2 shock questions
Post by JK Racing »
I believe the fronts are .6 and rears are .9, current shock cartridges fit also.
66intheSky
Oh ok....Thanx.
Brandon G
Post by Brandon G »
Yeah, the newer cartridges fit on all the old shock bodies. They seal and build better than any associated shock.
66intheSky
Thanks again.
Brandon G wrote:Yeah, the newer cartridges fit on all the old shock bodies. They seal and build better than any associated shock.
I don't know about that, but they are pretty good. I've had many less troubles with ASC shocks over the years than the Losi shocks on the
JRX2. The one o-ring cartridge was a bad design to say the least. It may reduce friction a bit but it certainly sells much more Losi shock oil.
JK Racing
Post by JK Racing »
66intheSky wrote:I don't know about that, but they are pretty good. I've had many less troubles with ASC shocks over the years than the Losi shocks on the JRX2. The one o-ring cartridge was a bad design to say the least. It may reduce friction a bit but it certainly sells much more Losi shock oil.
The newer cartridges are 2 o ring, I believe they changed the design quickly after the single o ring hit the ground - leaking :)
delsami
Post by delsami »
losi shocks are much better than ae....i am glad ae finally started fresh, it was overdue.
66intheSky
Yea, it was overdue......but your forgetting Kyosho Gold's. I think they were always the best IMHO.
Don't get me wrong, the Losi shocks on the JRX2 are good, but they leak too much (and I know, I
know....they were designed to do that initially with the single o-ring cartridges and the terrible shock shafts
at that time). But who wants a shock that leaks? I think the smoothness of the KG's was unobtainable on any other
buggy shock of the day, and they didn't leak at all for me when I was runnin them on my RC10 yrs ago. :)
66intheSky
JK Racing wrote:I believe the fronts are .6 and rears are .9, current shock cartridges fit also.
Anybody have the actual part #'s though so I can order them? (LOSA, LOSB, etc)
Thanx
badattitude
Post by badattitude »
I've have AE shocks and the Kyosho Golds now. I used to have the old JRX2 shocks BITD. IMHO the Kyosho Golds from 1988(ish) are still the best shocks. They are just great!
Any one know if the duratrax Kyosho Gold imitation shocks are any good? I almost bought the Duratrax shocks by mistake, I thought they were KGs.
66intheSky
badattitude wrote:I've have AE shocks and the Kyosho Golds now. I used to have the old JRX2 shocks BITD. IMHO the Kyosho Golds from 1988(ish) are still the best shocks. They are just great!
I still have all of em, and by far the KG's are superior IMHO, even better than the Platinums. Kyosho could never make cars that were up with the RC10's, JRX's, Schumachers,
or Yokomo's back in the day, but for some reason they could make great high end shocks. I've had a few of their cars (Turbo Optima and the first Ultima) and they were OK, but never the
performance of the others (until the higher end Ultimas came out).
PS The Dura-leak KG imitation shocks are junk. They drip like maple trees. The real deal are the KG's. Replacement 3mm o-rings
are easy to find for them (CRP makes nice nitrile ones, #1529 I think, look on eBay) but don't lose the small internal snap ring or the plastic
washers on the bottom when you rebuild! :shock:
Cheers :)
Return to “Losi Forum”
Users browsing this forum: User avatarradioactivity and 2 guests
