McAllister lowering kit take dye?
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
Is the McAllister lowering kit nylon or plastic? I’d like to dye it black, but it looks to be more like plastic. Will it take dye? I fear not…
- LTO_Dave
- Has thanked: 52 times
- Been thanked: 287 times
Re: McAllister lowering kit take dye?
Yes, the kit pieces will take black dye very well.
I used RIT liquid dye on two different kits and they only took a few minutes to turn a deep black.
- THEYTOOKMYTHUMB
I saw this build and it’s awesome. I guess I wasn’t paying enough attention. Thanks all.
LTO_DAVE, can you give us more info on those hinge pin retaing clips on the second picture? do they require grooves in the shafts?
- LTO_Dave
jwscab wrote:LTO_DAVE, can you give us more info on those hinge pin retaing clips on the second picture? do they require grooves in the shafts?
They are from Pure-Tech and mount in the grooves just like regular c-clips. They are slightly thicker, but work fine on my cars.
The have a flat side and a beveled side. And I bought a set of mini snap-ring pliers from Harbor Freight that work great...these little buggers are tough to spread apart.
- 669 Views
Last post by murphy3428
- 2871 Views
Last post by blubblood
- 2156 Views
Last post by Bent
- 2613 Views
Last post by Eau Rouge
- 1479 Views
Last post by TRX-1-3
- 34 Replies
- 2474 Views
Last post by treehugger
- 864 Views
Last post by RedScampi
- 1738 Views
Last post by mikedealer
