is there a decent fix for the front axles on the frog/brat/scorcher? took the kids brat out for its maiden voyage, and within 3 minutes the right front wheel fell off. The is press-fit into the knuckle.
Is there an adhesive that will keep it in place better?
is it possible to center drill and tap the axle and screw it in from behind? there does not appear to be much clearance in the carrier. Maybe if I change the socket head screw to a 4-40 button head there will be enough space.
Any ideas?
frog brat front axles falling out?
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
Re: frog brat front axles falling out?
I would use some red locktite and jam it back in there. I've heard of people drilling through and using a longer screw too. I haven't tried the drilling solution but red locktite has worked for me without incident.
- Brandon G
I had to drill and tap the axle to accept a flat head screw to hold it in on my Frog. I tried the red loctite 2 different times and it failed eventually.
- Been thanked: 12 times
Tried the red loctite over the weekend. put on a liberal amount after degreasing, then used a c-clamp to press the axle in firmly and let it sit clamped overnight. Ran a full pack through yesterday with no problems.
Thanks for the help!
- 38 Replies
- 5205 Views
- 1728 Views
Last post by THUNDERSTRIKE1
- 4057 Views
Last post by NomadRacer
- 1335 Views
Last post by sandkil
- 693 Views
Last post by Brat
- 745 Views
Last post by Asso_man!
- 787 Views
Last post by justinspeed79
- 1009 Views
Last post by durb69
