GT wide front axles
cautrell05
GT wide front axles
Post by cautrell05 »
How much wider are the 7222 wide front axles than the standard inline front axles? Thanks
Nick
justinspeed79
Re: GT wide front axles
Post by justinspeed79 »
IIRC they are 3/16" per side. I could be wrong though, it has been a while since I have used them. I use the T4 conversion now.
cautrell05
Thanks. What do you mean by the t4 conversion?
nick
soniccj5
Post by soniccj5 »
I hope this helps.
Part 7222
ED
cautrell05
soniccj5 wrote:I hope this helps.
Part 7222
ED
Thankyou very much. that tells me exactly what I wanted to know. Thank again.
Nick
justinspeed79
cautrell05 wrote:Thanks. What do you mean by the t4 conversion?
nick
You can use T4 caster blocks, in-line steering blocks, Kingpin, and axles. You have to ream the T4 caster blocks to make the hinge pin hole 1/8" so it will fit on the GT/T/T2 arms. You can just run a 1/8" bit through it, but it is better to ream it with a stepped reamer. If you just run a bit through it you run the chance of making a sloppy hole and throwing off the caster degree. It gives you the widening you want, but also improves steering geometry, and will handle better than the wide axles.
Return to “RC10 Truck Forum”
