That is not what I remember???
littlescreamers
Post by littlescreamers »
OK
Was just dosing on the couch and was thinking of the 4X4 conversion for the RC10
Now I do not remember the belt drive version?? I first seen the conversion in Texas 85-86-87? was a flex shaft coming off the tranny and going to the front drive!
Anyone else remember this conversion.
Scott
SteveK
Re: That is not what I remember???
Post by SteveK »
Yeah, the 4-10 was a belt-drive conversion in the early 90s. Plenty of discussions on it here, and I think the manual is in the Scans section.
civilguy
Has thanked: 5 times
Been thanked: 14 times
Post by civilguy »
Yes- the original 4wd kit had a flex shaft in a tube (like a Dremel flexible extension) that went outside the body. They caught on everything because you couldn't kink the tube enough to keep it in tight. :roll:
Jeff
civilguy
Post by civilguy »
Thanks scr8p-- I'm at work and I couldn't search for the pics. :lol:
I guess I should work. :oops:
Jeff
pancar
Post by pancar »
Cable drive, did somebody say cable drive? All I have left from the cable days is this front gearbox. Note the square drive in the center of the top gear. The funky part was the front driveshafts. Or should I say hooks. Wire hooks that were bent in a loop to go through holes at the ends of the outdrives. I guess they worked alright. Check out the top of the box. On the right it says "new chain drive system" and on the left the sticker says "new belt conversion", make up your mind!. I also have an older box for chain drive with no car on the boxcover, only text. I remember seeing a Super Champ conversion in a hobby shop once with the cable drive also.
Tom
MIP 4WD  front Gearbox
Years ago I started off with nothing ... and I still have most of it left.
You know that as soon as they make something "idiotproof" they'll just invent a better idiot!
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarTbot [Bot] and 4 guests
