Electrical battery charging question
Heffay
Post by Heffay »
I have a 6volt/12volt charger that charges at 2,4 or 6 amps.
It was originally meant for motorcycles batteries, and the like.
I now have a different charger for the bikes so it is collecting dust.
Could I change the connection on that to fit my 7.2volt RC car battery and use the 6volt setting at 2 or 4 amps?
My hobby battery charger took a crap and I'd rather not spend the money if it will work.
The hobby charger charges from 0-6amps and 4-5amps is recommended for the batteries I use, which are 3000mah.
Does the question come down to nicd/nimh type vs. the auto/motorcycle type?
Thanks.
JRX2 in the late 80s... have since come to my senses with the RC10T, yes of course it's vintage! Wife is always destroying her Tamiaya LunchBox to call me her personal mechanic a few more times. Enjoying the fresh build of an RJ Speed Digger.
iPearl
Re: Electrical battery charging question
Post by iPearl »
Arent motor cycles lead Acid ? Like cars ?
Heffay
Post by Heffay »
Yes, there are a number of types.
But ya, that is a good descriptor.
iPearl
Post by iPearl »
Comes down to the question if a Lead Acid and Nimhs/Nicd have the same charge properties or not.
Which i dont really know xD
Start digging around google w/o any luck.
Whats the chargers Model number ?
Heffay
Post by Heffay »
http://store.schumachermart.com/sc-600a.html
I have a batt that is still taking a charge but not anything I'd ever run again... should I just give it a shot? :shock: And do the fireworks run. :D
markt311
Post by markt311 »
make sure you're wearing a cup and an aluminum foil hat when you hook it up. And take a video too!
Mark
tamiya
Been thanked: 9 times
Post by tamiya »
Do NOT charge a subC nicad/NiMH pack with any charger made for Lead Acid 6/12v.
Yes it will "work" in that it will pump current into any battery... but it won't know when to turn off.
Lead Acids have a very different charging profile to Nickel & can tolerate some overcharging;
subCs are best charged with a peak-detect charger to avoid (damaging) overcharging.
iPearl wrote:Comes down to the question if a Lead Acid and Nimhs/Nicd have the same charge properties or not.
here ya go http://www.batteryuniversity.com/
All you ever wanted to know about Ni, Pb & Li 8)
iPearl
Post by iPearl »
now i know how turn lipos into a fire ball for fun.
Lead acid no peak detection lots of amps and fuzzzzzz
