battery question
- Been thanked: 81 times
battery question
Restoring a early gold pan . I want to assemble a box art battery pack. Will this get me started?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFD69&P=7
- transamman908
- Been thanked: 5 times
Re: battery question
Other than the label change, it should work. Heres the one out of my Edinger.
I have never built a battery pack before . But these sanyo's look close to box art. I will order these from tower and give it a go.
- Has thanked: 36 times
- Been thanked: 1318 times
or you could just buy one of these, cut off the shrink wrap, glue the cells together, and say......... close enough.
http://www.waldorfrc.com/servlet/the-4056/Duratrax-Sanyo-1500-7C/Detail
http://onlybatterypacks.com/
Tons of goodies on here; cells, end caps, wire, connectors, shrink wrap, etc. Even have end caps for smaller cells, for making mini stick packs.
The older manuals have instructions for building the battery packs in them.
But not the darn shrink wrap I've been looking for to make some repro old skool packs!SteveK wrote:http://onlybatterypacks.com/
http://www.wiringproducts.com/contents/en-us/d519.htmlfastang wrote:But not the darn shrink wrap I've been looking for to make some repro old skool packs!SteveK wrote:http://onlybatterypacks.com/
http://www.parts-express.com/wizards/searchResults.cfm?searchFilter=YELLOW+HEAT+SHRINK&srchExt=&perPage=27&sortBy=1&layout=list&page=1&srchPrice=&srchCat=&srchMfg=&srchPromo=&srchAttr=
Don't know if it's glossy or not, but keep trying 'yellow heat shrink' and see what you can find.
I can find the tube to go over the 3 cells in a line. If you look close in this pic you can see it is wrapped twice and the top layer is lengthwise and looks to hold the two- 3 cell sticks together. That's the stuff I can't find. It must start out 8 inches wide!
I bought some from Racers Edge but its not correct. It would need to be exactly opposite this stuff where the short end is open and the long end is tube like for lack of a better term. I need the long end open and short sides sealed.
fastang wrote:I can find the tube to go over the 3 cells in a line. If you look close in this pic you can see it is wrapped twice and the top layer is lengthwise and looks to hold the two- 3 cell sticks together. That's the stuff I can't find. It must start out 8 inches wide!
Not sure if this will work, but the bottom of the list is 4" PVC heatshrink tubing. Can choose red. It is 6 5/16" when flat, so just might be big enough to fit over those batteries lengthwise.
http://www.buyheatshrink.com/heatshrinktubing/pvc-heat-shrink-tubing.htm#B
Also found this, even larger
http://cvps.thomasnet.com/item/shrink-bands/pvc-shrink-bands-labels-tubing/pn-1628?&seo=110&bc=100|1007|3001020|3001021
christhepcguy wrote:fastang wrote:I can find the tube to go over the 3 cells in a line. If you look close in this pic you can see it is wrapped twice and the top layer is lengthwise and looks to hold the two- 3 cell sticks together. That's the stuff I can't find. It must start out 8 inches wide!
Bottom one looks promising! I'll give them a call, Thanks
- 898 Views
Last post by sneako43
- 2019 Views
Last post by Jeep-Power
- 904 Views
- 2164 Views
Last post by Brandon G
- 804 Views
Last post by templeofspeed
- 1913 Views
Last post by madmudder
- 713 Views
- 1045 Views
Last post by iPearl
