A possible alternative to servo tape
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
I bought some of this stuff to hang a picture frame and it is freaky strong and peels away clean. It is a lot stronger and has no fuzzing effect like velcro. Might be handy to someone who needs to switch out receivers or escs a lot. I bought it at Lowe's, but you can probably get it anywhere. Mine was yellow, but I think this is the same. I think one strip holds up to like 20 pounds. I believe it after peeling it apart.
http://www.lowes.com/lowes/lkn?action=productDetail&productId=70377-98-17202ES&lpage=none
- tamiya
- Been thanked: 9 times
Re: A possible alternative to servo tape
that Command stuff is ok but my motorspray weakens it... wouldn't be using it for servos
if you want strong checkout 3M VHB, or the clear silicone doublesided tape - i'd trust those to hold up mirrors in your bathroom!!
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
VHB is repackaged and sold by Parama--
I use VHB for all servos'
I did this to one of my nitro cars during a test and tune at a very tacky track, absoutley destroyed the entire front end when some goof left a loop of zip tie on the outer wall, the car went from 40mph to zero in 1 foot, chassis, arms, bulkhead, towers etc--------but the servo was still in place
VHB is bein sold at Homedepot the rubber stiky substance is grey and teh film is red.
The same film is being rebranded inteh car industry for Bumper accent panels Grey sticky piece and red cover tape.
Walmart and Home depot costs about 5 bucks for small roll 10 for Huge one.
It sticks hard and when you take it off it doesnt leave dum resdue back. that you have ot rub off.
- tamiya
VHB has its uses but seriously, servo mounting isn't one of them - servos are a
mechanical actuator and it needs a solid mechanical mounting = posts+screws
If you want your servos stuck on that hard, use ShoeGoo
it won't flex
yes it needs overnight-24hrs to cure properly, but so does a proper VHB bond
For most stuff... i use the black auto/all-weather foam tape where vibration protection is required.
For heavier stuff (ESC with big heavy heatsink & fan) i might use the 3M clear silicone tape.
Degrease both surfaces with isopropyl alcohol and they'll stick as strong as you ever want.
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
I agree with charlie I use VHB for all servos' i bought the jumbo roll home dep
i build them run them for a week then pullem apart and do somethinng else i had a glitch on my lazer steering servo slammed itno a chainlink fence post on the rebuild i push a flat bladed screwdriver under the servo and leave it for 10 mins and then repeat untill realeased
+1 on the VHB, BrandonG told me about this stuff a few months ago. it works great for servos and anything else. I forgot the battery strap for my team car one race day, I used 2 one inch strips to hold my battery in, it is still holding strong after 4 race days. And I crash a lot! lol
Mark
- 1770 Views
Last post by surgetek
- 1239 Views
Last post by juicedcoupe
- 906 Views
Last post by SmallScaleSmitty
- 31 Replies
- 3581 Views
Last post by Dr. Robotnik
- 201 Views
Last post by helbnd1
- 1867 Views
Last post by SRTracer121
- 602 Views
Last post by soniccj5
- 1654 Views
Last post by LowClassCC
Users browsing this forum: jcwrks and 7 guests
