Composite Craft Worlds Car Graphite Chassis set
- transamman908
- Been thanked: 5 times
I have a nib Composite craft worlds chassis and would like to build and complete it. I have found some photos and other info on here, but still have qhestions. I know that a rc10t or gt front bulkhead will be needed. What arms do i use and do they have to be rpm's? Also, can a stock rear bulkhead be used? Basically i'm looking for a list of parts needed to complete this as far as suspension parts. Thanks
- Has thanked: 36 times
- Been thanked: 1318 times
Re: Composite Craft Worlds Car Graphite Chassis set
if you don't have rpm worlds arms, your only other option would be the dynotech klein replacement arms (part #2700/2701). as for the rear bulkhead, a stock one should be fine. you may have to notch the side of the battery box area for clearance for the a-arms. you'll probably want to look for the worlds rear hub carriers, or the rpm rc10gt rear hubs will work. on the front, yes, you'll need a 10t/gt front bulkhead, rpm worlds or dynotech arms, and you can use the stock associated castor blocks and steering knuckles/axles.
don't forget the worlds rear arm mounts, too.
- transamman908
Great, Thanks. I also notice that my chassis has a small notch by where the steering servo would mount. Why is it there, I don't notice it on others i've seen.
that's for servo saver clearance. i don't remember ever seeing a "worlds" chassis that didn't have that cut out.
- transamman908
I was checking out the post in the ebay talk section and noticed it, but maybe it's not a worlds chassis
no, it's a worlds chassis. it could just be an early version..... or something like that.
- 40 Replies
- 7325 Views
Last post by DR STATIC
- 26 Replies
- 4048 Views
Last post by MarkyDents
- 1051 Views
Last post by badhoopty
- 26 Replies
- 3276 Views
Last post by wyldbill
- 1187 Views
- 2305 Views
Last post by Showcase1186
- 1013 Views
Last post by JOHNBOY74
- 2216 Views
