Could someone advise me which alternative wheels would fit the Kyosho Progress / Gallop ?
Thanks in advance
James
Wheels which fit Kyosho Progress / Gallop
- highwayracer
- Been thanked: 6 times
Re: Wheels which fit Kyosho Progress / Gallop
hello James,
It depends on the tires you're going to use and how much you're willing to modify your car.
You can actually run the hex style wheels on the gallop. Even though it doesn't use a hex, there's enough friction created by the gallop "circle" to be able to do this.
The gallop uses 2 different diameter wheels. The fronts are a little bit larger than the rears. The rears are the same size as the rear wheels used on the original Kyosho Raider (same rear tiers are used). I don't know of any front wheel that can be used on the gallop and still be able to use the same front tire size.
If you're ok with not using the original tires, then you can use wheels/tires from the original optima/javelin.
As for other brands, wheels from the hirobo zerda, marui samurai and aristcraft kangaroo (rears) also use the circle press fit. Again, by using these wheels, you may no longer be able to use the stock gallop tires since they may be a different diameter. When I think of this more, you can even use the original rc10 rear wheels on the front and rear of the gallop.
Are you looking to upgrade the wheels of your gallop?...or do you not have the original wheels?
Regards,
highwayracer
Regards,
highwayracer
HI Highway,
Thanks for the detailed answer, I have a progress which is in good condition but the wheels are looking a little tired and the tyres arent great so wanted to spruce it up a bit. Im happy to put something different on besides standard, i had suspected i would be about to 'press fit' several brands on but wanted to check if there were any alternatives out there that would drop straight on.
Im looking for a gallop cage also if you know of anything.
Regards
James
Regards
James
- 1082 Views
Last post by DennisM
- 1447 Views
Last post by Huntit123
- 1146 Views
Last post by rccars4sal
- 1575 Views
Last post by sk7
- 989 Views
Last post by unixphreak
- 1526 Views
Last post by RedScampi
- 3427 Views
Last post by JakeDriver
- 4410 Views
Last post by keithrc
