Yokomo Chassis
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: Yokomo Chassis
Purely based on the look of the countersunk holes I'd say glassfiber. The cut edges and countersunks on a graphite chassis are darker than the ones on black coloured GRP.
Get a second opinion though
Re: Yokomo Chassis
Is there an online Delta catalog avalible...I looked in the Scans Archive and it seems void of Delta info.
- mikedealer
Re: Yokomo Chassis
for the $25.00 price tag even at the time, im going to say its fiberglass, based on the look of the holes also.
Re: Yokomo Chassis
The first one is black fiberglass (based on the same observations as mr lexan), and the second one is a combination of carbon outer layers with a fiberglass core. This is very popular from that era. The center layers of a composite offer little strength, so by using a less expensive alternative at the core, (eg. fiberglass) one was able to keep down costs when compared to a solid carbon or graphite piece. While at the same time offering similar physical characteristics (although slightly heavier). -Jeff
- Mr. ED
Re: Yokomo Chassis
JD is fully right, and while being heavier it is in a way helping to keep your CG lower
- 1381 Views
Last post by Triniboy
- 1820 Views
Last post by Westhamu5
- 32 Replies
- 3723 Views
Last post by minimini
- 3491 Views
Last post by Dr. Robotnik
- 3779 Views
Last post by RC10resto
- 654 Views
Last post by mm.yokomo
- 3651 Views
Last post by phoenix
- 1203 Views
Last post by shodog
