JRx2 full RPM/A&L tuned
kenooze  It’s my birthday!
Post by kenooze »
I finish this WE one more project, a JRx2 tuned with RPM plastic parts like Front bulkhead, arms, spindles and carriers, steering levers, battery box, side mounts, rear brass, gear cover, U joint and shock spacers. I complete this with front & rear shock towers, Lunsford turnbuckles, Trinity front wheels and ProLine rear's...
Enjoy :wink:
aconsola
Re: JRx2 full RPM/A&L tuned
Post by aconsola »
Awesome!
just missing one little detail, no front body mount, and no easy way to put one on there with the rpm front bulkhead not having the holes on the top like the later version. It's probably just as well, one less hole to cut in the body.
great job, did you drill for the rpm battery cup or just use the stock holes?
Post by kenooze »
That's the question.
I will ask Darryl about this.
The label said should be fit body mount, may be the same than on rear.
About battery box, I use the standard holes, I need to check the real position of the battery box with a saddle pack before drilling.
Thanks
Cedric
aconsola
Post by aconsola »
the body mount for the front is different than the rear one. both towers list #3110 as the part # for the body mount. you can see what it looks like on the instruction sheet for the short tower.
JG made a body mount that is very similar in design, part#1804. Neither body mount will work for you as the RPM bulkhead you used is the +10 degree caster version, which does not have the open holes on the top to screw the body mount into.
m2fit4u2
Post by m2fit4u2 »
She's Gorgeous.
Great pictures, thanks for sharing.
RETRO R/C
Has thanked: 11 times
Post by RETRO R/C »
Very Very sweet my friend.
Such an awesome looking car the JRX2 - especially all blinged up.
Cheers
Darryn
TO KNOW WHERE YOU ARE GOING - YOU HAVE TO KNOW WHERE YOU HAVE BEEN
VENOM International | Factory Pilot - Team SCHUMACHER UK | J-Concepts USA | B-Fast Performance USA | Bugle Boy Racing | MAX Racing Products International
karnivool
Post by karnivool »
i bet there is a nice slipper under that rpm gear cover, i have a spare aerial mount cap in black if you need it also :)
Post by kenooze »
About the antena mount cap, I'm eventually interrested, thanks for the offer ...
About slipper, I on way to put the A&L but not sure to be available at the right period ?
delsami
Post by delsami »
nicest 2 i have ever seen!
bearrickster
Post by bearrickster »
kenooze wrote:About the antena mount cap, I'm eventually interrested, thanks for the offer ...
The antenna is still available :
http://cgi.ebay.com/Losi-Antenna-Kit-LOSA4002_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116QQhashZitem35a0803f58QQitemZ230326026072QQptZRadioQ5fControlQ5fPartsQ5fAccessoriesQQsalenotsupported
LOSI RULES!!
Bearrickster's Rides
Return to “Losi Forum”
