Powdercoating VS. Anodizing
Re: Powdercoating VS. Anodizing
what about buffing or polishing instead of powder or anod. ? i never see anybody with blinged out RC10's
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
The surface will dull very quickly from oxidation to the air. Clear coating is needed if you want to keep it real shiny.
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
You're right on the powder process, and it creates a "bonded" surface that coats the metal itklavy69 wrote:I was kinda hoping for this exact thing myself. Like the elcheapo powdercoater I was lookin at has a model that does 5-10psi and another model that goes 10-30 psi...what is this all about? I was thinkin powdercoating had everything to do with the current/electrical charge between the part and the gunreghammer wrote:I'm kind suprised no one here has mentioned how the two processes work.I've seen pix of guys doing their own annodizing over at NitroDan's board of AffordableNitroTechRacing a long time ago but it looked like globs of paint that dribbled on and that was about it...can anyone clarify this stuff up?
Thanx again for the comments guys and nice lookin chassis to all that posted. They wouldn't look that good if they were at my house.
it is, well....covering
While Anodizing is also a positive/negative charge (in a chemical bath) but actually causes a chemial oxidation to the aluminum--and certain chemicals cause different color crystals to form just under the surface of the alloy.
Powdercoating is more scratch resistant (but is not maliable and chips upon impact)
while ano is only a couple hundred thoulsanth's into the alum (or titanium) surface but as a
result very scratch prone
BTW any one here can anodize with
1) 12v DC powersupply
2) 10 gallon plastic cooler
3) correctly mixed chemical bath
4) positive wire "tree"
5) stripped & prepped aluminum
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Very interested to find out the rest of the equation. I have #1,2,&5 taken care of but have no clue to your #3 and believe I have an incling on your #4. I'm figuring your pos. wire tree is what you attach your parts too and have your 'power' wire hooked to for your electrical charge. Is there something somewhere that I can find more out about it? Thanx reghammer for reviving this one.reghammer wrote: BTW any one here can anodize with
- klavy69
- Moderator
I've got a NDS that has a mirror like finish on its chassis but the thing has been a shelf queen most of its life...til I got itInspector Gadget wrote:what about buffing or polishing instead of powder or anod. ? i never see anybody with blinged out RC10's
- Mr. ED
Forgot: anodizing is also possible colorlessMr. ED wrote:The surface will dull very quickly from oxidation to the air. Clear coating is needed if you want to keep it real shiny.
Google "anodizing" or "anodizing chemicals" and you will come up with plenty--there are plentyklavy69 wrote:Very interested to find out the rest of the equation. I have #1,2,&5 taken care of but have no clue to your #3 and believe I have an incling on your #4. I'm figuring your pos. wire tree is what you attach your parts too and have your 'power' wire hooked to for your electrical charge. Is there something somewhere that I can find more out about it? Thanx reghammer for reviving this one.reghammer wrote: BTW any one here can anodize with
of companys that sell the powder mix for the bath--you add the electrolytes etc..
MAKE SURE TO PRACTICE FIRST--different alloys (t7061-7031) and so on anodize with diffferent
results and different times to produce the desired effect, and on resto's your batch of used parts
may have different compositions due to year, supplier, machinist and so on, so you may ano
3 tub chassis and get 3 different hues of gold with the same bath time--
also titanium doesn't subscribe to the color that you use, a black bath will produce a gunmetal
grey, blue is yellow and so on
- klavy69
- Moderator
Cool,
Thanx for the info. Will have to do some searching on it when I get a chance.
- 1882 Views
Last post by tecnica2001
- 1842 Views
Last post by morrisey0
- 1096 Views
Last post by utieh
- 338 Views
Last post by treehugger
- 20 Replies
- 2168 Views
Last post by flipwils11
- 1056 Views
Last post by KidAgain
- 1856 Views
Last post by helbnd1
- 801 Views
Last post by Qballll
