Rc10B3 basher
- Been thanked: 19 times
Re: Rc10B3 basher
Yea there is usually some un-fudging you have to do with used cars. But once you get them squared away it's fun.
Current:RC10T, T3 FT, GT Blue Tub, GT FT, GT2 FT, GT5, RC28, SC28, Micro RS4.
Previous:B2, B3, B3 FT, 10T pink chassis, GT FT, TC3, TC3 FT, RS4MT
Tamiya TA02, Thunder Tiger TS4N pro, Kyosho VoneR, Emaxx, MX4, MP 7.5, 7.5 Kanai.
- Has thanked: 14 times
- Been thanked: 5 times
Re: Rc10B3 basher
I bought a Flysky gt3b , and right now I am hating it. It doesn't have much steering trim adjustment , so I tried adjusting the servo arm to get a decent center. No luck. Swapped a longer arm on, no luck.
I'm wishing I had stayed with a transmitter that had normal adjustment knobs and not a small range of movement, probably due to the use of a digital screen.
Anyone want to buy a new TX/rx?
Re: Rc10B3 basher
I have that radio and it works great. No problem adjusting the trim here. Though I do agree I like a knob better.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: Rc10B3 basher
I don't need to edit or delete it. Read the rules and keep it off the boards and I wouldn't have had to delete or edit it to begin with.RS Chris wrote:PM sent.
CANT EDIT OR DELETE THAT ONE KLAVY!
Re: Rc10B3 basher
I finally got the arm and linkage adjusted so that with almost all of the controller adjustment to the left dialed in, the car goes straight. Wouldn't you know it, the long arm doesn't fit under the body.
Re: Rc10B3 basher
Is there a way to get more trim adjustment? This setup worked fine with two other controllers. I'm thinking I'll go back to the short arm and build another rod/end setup with more adjustment.SiRacer420 wrote:I have that radio and it works great. No problem adjusting the trim here. Though I do agree I like a knob better.
Re: Rc10B3 basher
I noticed you deleted the post all together. Good for you big bad moderator.klavy69 wrote:I don't need to edit or delete it. Read the rules and keep it off the boards and I wouldn't have had to delete or edit it to begin with.RS Chris wrote:PM sent.
CANT EDIT OR DELETE THAT ONE KLAVY!![]()
Re: Rc10B3 basher
Jimbo302 wrote:Is there a way to get more trim adjustment? This setup worked fine with two other controllers. I'm thinking I'll go back to the short arm and build another rod/end setup with more adjustment.SiRacer420 wrote:I have that radio and it works great. No problem adjusting the trim here. Though I do agree I like a knob better.
I just trimmed it a LOT. I went in increments of 5.
Re: Rc10B3 basher
Put the short arm back in adjusted everything, got it right. Went through the transmission, rebuilt the diff, installed the b4 top shaft and slipper. Did some more tinkering on the suspension, made sure everything was good and threw a 2s in it.
This car is faster than I thought and handles pretty good. My oldest daughter is going to pilot this one, so I'm crossing my fingers.
Re: Rc10B3 basher
Toned it down with a 20t brushed motor so she can learn how to drive it. I had to dremel out the opening in the motor plate to fit the brushed motor.
Re: Rc10B3 basher
I stuck a low pinion gear on the 20t motor and with a 2S lipo it will wheelie from a stop and run a nice calm top speed. Perfect for a lot fun without too much risk.
- Has thanked: 35 times
- Been thanked: 10 times
Re: Rc10B3 basher
nice to be able to keep your hobby in the family ! have fun.
btw: does she want extra power already?
- 23 Replies
- 3241 Views
Last post by Synergy
- 1545 Views
Last post by Kaare-65
- 812 Views
Last post by RCMA
- 1724 Views
Last post by adam lancia
- 1079 Views
Last post by Snake Plissken
- 71 Replies
- 8755 Views
Last post by R6cowboy
- 1111 Views
- 1208 Views
Last post by mikesofunny
