Here are the pictures showing you CAN adjust the timing. Blue ring - 10.5, Yellow ring - 17.5
Hcp22 wrote:Okay Paul, tell me what to buy then, I won’t settle for good start!Lonestar wrote:both are a good, pragmatic solution... doesnt mean the rest is necessarily crap, but this is a good startHcp22 wrote:So if the newbie have got this right is Hobbywing 60A Xerun 2.0 or 2.1 the way to go?![]()
How about the 17.5 motor?![]()
Paul, I’m appreciating that you are taking the time to help out.Lonestar wrote:
I meant both HW, speedo and mill
now... do you really want a $100+ combo in your scorpion? xerun might not be needed... ezrun will be plenty enough. 17.5 might also be too much for the old lady, you could go even milder...
if you're into this ballpark of HP and you don't necessarily need sensored stuff, this should be ok
http://www.ebay.com/itm/HOBBYWING-ezrun-RC-sport-car-13T-brushless-motor-35A-ESC-3in1-combo-TRUCK-BUGGY-/200778603214?pt=Radio_Control_Parts_Accessories&hash=item2ebf565ace
Paul
Hcp22 wrote:I found this cart some years back on other forum, so I wonder if there is any relevance in this cart. I recon it differs from brand to brand...
9.5T brushless = 17T brushed
10.5T brushless = 19T brushed
13.5T brushless = 23T brushed
15.5T brushless = 27T brushed
Down far right you have X on your posts85Edinger wrote:I thought 17.5bl= 27 brushed.
Edit: oops, how do I delete this?
well i'll be....that's odd from what i understood novak commited to the dodc (dirtoval.com) series and the ss17.5 was the motor.85Edinger wrote:Okay, so I just went to look for the Novak SS 17.5, and I can't find it anywhere! Is it discontinued?
Edit: I saw that it is no longer part of the Novak product line, but Bumps and Jumps has it.
85Edinger wrote:Either way, it's $85. Anywhere to get it cheaper?
Edit: never mind, that's actually a pretty good price.
For Vonats you need an ROAR approved 17.5 motor or?Lonestar wrote:85Edinger wrote:Either way, it's $85. Anywhere to get it cheaper?
that's my point... why spend that much money on a non-competition motor? I've won races with 40+ pilots with $20 chinese mills... in 2wd, anything is almost too much power and efficiency isn't an issue...
Paul
