Nvxwax's Trailing Arm Hot Trick Build (Updated 05/12/12)
flipwils11
Been thanked: 19 times
Re: Nvxwax's Trailing Arm Hot Trick Build (Upadted 03/12/12)
Post by flipwils11 »
nvxwax wrote:
flipwils11 wrote:You gotta get that red transmission that was on fleabay to complete this thing and do it up proper!
I wish i could, id like to know who got it :)
For now i have a stock motor plate being anodized for it :)
You can look back in the ebay auction history if it's still there, contact the seller, and ask nicely if they'll tell you the username or send a note on your behalf to the seller with your contact info. Or you can just look in the seller's feedback history and maybe determine who the buyer was if they left feedback.
lexus-5
Been thanked: 11 times
Re: Nvxwax's Trailing Arm Hot Trick Build (The Start)
Post by lexus-5 »
nvxwax wrote:Thanks guys, Yeah its a neat setup, I like different things lol :)
lexus-5,
I missed that trans setup also :( no funds at the time lol, if i'm not mistaken it didn't go very high either :( I am trying to get someone to anodize a motor plate and front skid for now, I'm hoping to find some originals in new condition at some point lol.
Is your motor plate a HT part or a re anodized AE part?
Mine is a re-anodize by the same guy in New Mexico that did the Rio Rancho RC10. It is very close to the original Hot Trick red color.
Remember it's either a runner or a shelfer. Everything else is just parts.
Check out my Gallery for more Collection Pictures http://www.rc10talk.com/viewtopic.php?f=77&t=20697
nvxwax
Post by nvxwax »
lexus-5,
I have mine sent out to Emerson :) It should match pretty close :)
nvxwax
Post by nvxwax »
Ok time to update this thread, I have made a little progress on the HT build.
Added some alloy wheels (Not sure of the brand, Maybe someone can help)
Wrapped the wheels with some vintage proline tires (I had a bunch left over from the tire lot lol)
Satin Polished some bottom load shocks (I liked the way the looked on my New BBT build)
Installed a Twister Mod Motor because its read lol
Used a litesink motor plate, I might change it out when the red one arrives (Held up for a bit in china)
Im still working on linkage, I dont have anything that will work with that HT design bellcrank, I have almost given up on it and have a message out to a member for another option that would remove the HT parts altogether lol
Thats about it for now, Do you think the wheels/tires look right on this build? Or should i go with some RCP/Losi Front and Rear Alloy Centerline Covers like i used on my A&L Build
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
nvxwax wrote: Added some alloy wheels (Not sure of the brand, Maybe someone can help)
Look like Mini-Mags to me.
BTW if you linked the rear hub carriers to the rear bulkhead instead of onto the arm like it is how does camber change during compression?
nvxwax
Post by nvxwax »
Thanks,
Im not sure what effect it would have if the links were hooked to the bulkhead, The rear carriers are at a weird angle you cant see from the pictures, It might bind up a little setup that way.
fredswain
Re: Nvxwax's Trailing Arm Hot Trick Build (Upadted 05/03/12)
Post by fredswain »
It may or may not bind but you will definitely get lots of negative camber as the suspension compresses.
flipwils11
I really like the silver shock contrast with the red. No matter what the real quality of Hot Trick stuff is, it sure seems to be well suited to shelfer status! :P
nvxwax
Post by nvxwax »
Thanks Adam,
I might change out the trans for a white 48 pitch thorp 6gear when my red motor plate arrives, Id like to use the MIP and Litesink motor plate on my New BBT
I like the silver shocks also, I have been up in the air for a wile on what shocks to use, Gold would kust look funny on a car with all red, silver and white parts.
nvxwax
Re: Nvxwax's Trailing Arm Hot Trick Build (Updated 05/03/12)
Post by nvxwax »
Here are the weekend Updates
Finally got the HT bellcranks hooked up, what a pain in the a$$.... Also mounted a Protech ody, This body was for my A&L car but after cutting on it i found it did not cover the A&L chassis lol, So it went on this car, It actually fits pretty good, a lot easyer to mount then the A&L car, The front is not quite as close to the front skid as i would have liked but like i said it was cut for the A&L then moved to this build lol
frgna
Re: Nvxwax's Trailing Arm Hot Trick Build (Updated 05/12/12)
Post by frgna »
Impressive build! Also curious on the wheel brand if anyone knows.
Phin
Post by Phin »
frgna wrote:Impressive build! Also curious on the wheel brand if anyone knows.
Six posts up from yours.
THUNDERSTRIKE1
Post by THUNDERSTRIKE1 »
THATS THE BEST hot trick conversion ive ever seen.But i like polished wheels and red car.What color painting the body?don
kaiser
Post by kaiser »
that car is hawt!
i bet it wouldn't last 4 minutes without bending something, but it sure looks cool as hell. nice shelfer for sure!
Users browsing this forum: No User AvatarDotNetDotCom.org [Bot] and 2 guests
