Kyosho now on the re-re bandwagon - Scorpion
The place for all things re-release Kyosho.
KyoshoScorpionKid
Does anyone have the specs on the original I want to compare
Post by KyoshoScorpionKid »
This new scorpion to the old.
Chassis Technical Data
Length
398mm
Width
236mm
Height
145mm
Wheelbase
263mm
Tread (F/R)
198mm /195mm
Tire(F/R)
75×20mm / 85×41mm
Gear Ratio
H setting 6.9:1、L setting 8.3:1 (2 combinations included)
Weight
985g approx.(w/out R/C system & battery)
Motor
540-class
KyoshoScorpionKid
Re: Does anyone have the specs on the original I want to com
HOLY either my math is wrong or these are way off from the original car. This is the original Turbo Scorpion.
YOSHO RADIO CONTROLLED TURBO SCORPION 1/10TH SCALE MODEL # 9082
OFF ROAD RACER ELECTRIC POWERED RACING BUGG
THIS IN NEW IN BOX (BOXED WAS OPENED FOR PICTURES) NEVER PUT TOGETHER
COMPLETE WITH INSTRUCTION BOOK AND QUICK CHARGER
LENGTH/15.75" WIDTH/8.86" TOTAL WEIGHT/58.2 OUNCES WHEELBASE/10.24" GROUND CLEARANCE/1.18"
FRONT TRACK/7.16" REAR TRACK/7.32" FRONT TIRE/2.87 DIA. X .71W REAR TIRE/3.30 DIA X 1.57W
MOTOR POWERFUL, HIGH TORQUE MABUCHI RS-540S
ADDITIONAL ITEMS REQUIRED FOR RUNNING (NOT INCLUDED)
COX/SANWA NO. 8220 TWO CHANNEL RADIO SYSTEM
COX NO. 9086 7.2V NICAD BATTERY PACK (6N-1200)
12 AA ALKALINE BATTERIES FOR RADIO SYSTEM
I converted weight of 58.2 ounces to grams and it came to 1649.9 grams! and the new one is only 985 grams! Whoa!
KyoshoScorpionKid wrote:This new scorpion to the old.
This is the NEw
Length
398mm
Width
236mm
Height
145mm
Wheelbase
263mm
Tread (F/R)
198mm /195mm
Tire(F/R)
75×20mm / 85×41mm
Gear Ratio
Weight
Motor
540-class
ron
Re: Kyosho now on the re-re bandwagon - Scorpion
Post by ron »
I am going to set all electronics - for the 1/16 scale. Servos, ESC, battery and motor will all be smaller. I am panning to use the Traxxas 1/16 scale trucks 380 brushless motor, electronics and lipo battery, should have plenty of grunt and power. Considering the scorpion is a very light buggy even though it is 1/10, the 380 brushless should work beautifully and the buggy will be quite light.
I am going with this setup because I feel that the 380 motor is a really scale reference to the overall size of the buggy. The 540 can dwarfs the scorpions back. Take a look at the scale of the 1/7 scorpion and the relative size of motor to body size, it works very well doesn't it.
I am not saying that you should put a 380 in your 1/10th ride, but the idea sure works, brushless power - less heat, lightweight better performance. I have not tried it yet but this is the way I am going.
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Post by EvolutionRevolution »
One is with electronics and battery, the other without.
rccars4sal
Post by rccars4sal »
Raman wrote:The progress came before the Optima right? I think it had 4 wheel steering?
Yes progress gallop were the first 4wd ep buggy offering from Kyosho. Before that I think they had an ep 4wd chevy truck, and some nitro 4wds.
correct again 4ws. Extremely awsome complex buggies. Not very fast due to draggy drive train, and suspension is limited,, but a very dramatic and exciting ride! FUN!
I'd actually disagree with the "fun" part, regarding the driving of the Progress/Gallop. Even reviewers back then (I seem to remember reading one in RCCA about the Gallop) said that with the 4WS, the cars actually turned TOO good, you didn't get any of the fish-tailing and dirt rooster-tailing that you'd usually get with a non-4WS car...and that's the fun stuff. :mrgreen:
rccars4sal
I really enjoy the tight turning, noise, and drama from the little chunky pg cars. To me,, theyre the funnest of the not so fast racers.
TM Ru22311
Post by TM Ru22311 »
Anyone have any suggestions for the electronics, motor upgrade, etc. for the new Scorpion??? I have to get a Tx and everything. I may try to find a used one. I can't wait to build this soon. :mrgreen:
proffesso
Post by proffesso »
one of those new lemans series brushless would be my pick for this, and any red servo/esc/rx I could find
I'm a retro radio control hipster - I only like the stuff no one bought!
TM Ru22311
The specs say it recommends a 30T-27T motor, do they have brushless motors that are within those specs? Most of the ones I have seen are 15T or less. Are you guys planning on going with a LiPo setup as well?
Raman
Has thanked: 7 times
Post by Raman »
You can run a 17.5 in it without a prob. The tranny will probably handle even a 13.5 but the suspensions geometry will not handle the speed
markbt73
Post by markbt73 »
I have a nice old LeMans 360ST that might get the nod. A little outside the recommendations (it's 22 turns, if I recall), but it just seems right.
rccars4sal
Back in the day, I ran a 240st in a progress,, so surely this new scorpion can handle more power than that.
Hcp22
Has thanked: 33 times
Been thanked: 22 times
Post by Hcp22 »
What motor the gearbox can handle isn’t the problem, gearing is. Its modern diff and slipper, so I think it can handle any motor, but there is only 6.9:1 and 8.3:1 gearing to choose between. Kyosho need to come up with an adjustable motor plate or someone else will.
I think there will be some hop-ups for the Scorpion from Kyosho depending on how many cars that get sold. I don’t think this is a limited edition, but I can be wrong.
Cheers
Lars
My Feedback
TM Ru22311
Hcp22 wrote:What motor the gearbox can handle isn’t the problem, gearing is. Its modern diff and slipper, so I think it can handle any motor, but there is only 6.9:1 and 8.3:1 gearing to choose between. Kyosho need to come up with an adjustable motor plate or someone else will.
This is what I am concerned about. I would like to go with a modern power setup, but not something that will be to hard on the buggy. LiPo is appealing because you get more fun time though. I don't really know much about RC cars, so I will have to wait and see what some of you guys go with before making any purchases. I am anxious to get the buggy and assemble it though, I just hope it doesn't turn into a shelf queen (for me). I want to run it.
Return to “Kyosho Re-Release Forum”
