My first KYOSHO SCORPION!!!
Bormac
Has thanked: 20 times
Been thanked: 11 times
Post by Bormac »
Ok so I have been really busy with buying stuff from all over the world and usually its vintage Schuey stuff but recently its been alot of Kyosho also.This is the first of a couple of old Kyosho buggies which are on the way.This is just an early shot of a little project I have in mind.
-Jason.
Still known as- bormac
RETRO R/C
Has thanked: 11 times
Re: My first KYOSHO SCORPION!!!
Post by RETRO R/C »
Interesting!
HAs Icarus front wheels on it.....plus another couple of differences?
Is that the shell you were telling me about last night mate? If so - its not a kyosho "Beetle" shell........ :cry: Still is a bit of a looker though! 8)
Cheers
Darryn Johnson
TO KNOW WHERE YOU ARE GOING - YOU HAVE TO KNOW WHERE YOU HAVE BEEN
VENOM International | Factory Pilot - Team SCHUMACHER UK | J-Concepts USA | B-Fast Performance USA | Bugle Boy Racing | MAX Racing Products International
germanrc10gt
Post by germanrc10gt »
wow looks awesome. what body is that. i ordered two parma beetle bodies for my baja project last night.
don't look like a parma beetle :?:
mrlexan
Post by mrlexan »
I believe that is a hard ABS style body from Kamtec in the UK.... http://www.kamtec.co.uk
www.gojammedia.com
Bormac
Post by Bormac »
The body thats on this chassis now was included on the RC10 CE I got from Toymaker73.This is the body Im thinking of running on this car.As for the original Scorpion Beetle body I will get a picture up soon.Im dead keen on getting some alloy whels mounted up on all four corners so these wont stay on for long.
RETRO R/C wrote:Interesting!
Cheers
Darryn Johnson
-Jason.
shodog
Been thanked: 91 times
Post by shodog »
good luck oin finding a set of aluminum wheels. The rear hubs are a pressure fit. The front uses a 4X8mm metric bearing
mrlexan
Post by mrlexan »
I know that Sees alum wheels for Kyosho are pressure fit. The only problem is, you never see them. You might be able to go the hex Kyosho route, but the axle length maybe a problem. I can't remember for sure, but I want to say that early Kyosho pressure fit axles are shorter than the later verisons. Another alternative, you could use a set of CRP hubs for the Scorpion that were made to use Tamiya (SRB) wheels. The only issue there would be finding a set of wheels that would work with the pin presseed in the CRP hub.
www.gojammedia.com
terry.sc
Has thanked: 7 times
Been thanked: 157 times
Post by terry.sc »
Looks good there. The body is specifically the Kamtec oval window body
http://www.kamtec.co.uk/products.php?Prod_ID=23&prod_cat=2
originally designed for the M chassis Beetle, not the kamtec Baja shell.
Axles are easy. The Scorpion uses unique 6mm flanged bearings on the axles, tapering down for the rest of the axle. The friction drive washer means wheels made for the SRBs would also fit on the axles. the easy part is replacing the axles, the hub in the swing arms is narrow enough for any metric from Kyosho or Tamiya axle to fit no problem so you can use hex drives on the rear, but you will need a set of flanged 5 x 10mm bearings for them.
badhoopty
Has thanked: 183 times
Post by badhoopty »
terry.sc wrote:Axles are easy. The Scorpion uses unique 6mm flanged bearings on the axles, tapering down for the rest of the axle. The friction drive washer means wheels made for the SRBs would also fit on the axles. the easy part is replacing the axles, the hub in the swing arms is narrow enough for any metric from Kyosho or Tamiya axle to fit no problem so you can use hex drives on the rear, but you will need a set of flanged 5 x 10mm bearings for them.
is this place great or what?
:D
templeofspeed
Been thanked: 33 times
Post by templeofspeed »
This is a great place!
8)
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarAhrefs [Bot], User avatarSwath and 3 guests
