Thorp Dirt Burners Losi JRX2 LRM Gears
Nige55
Has thanked: 7 times
Been thanked: 14 times
Re: Thorp Dirt Burners Losi JRX2 LRM Gears
Post by Nige55 »
BattleTrak wrote: Sun Aug 28, 2022 9:18 pm The Thorp Delrin top shaft gear also fits properly on the Losi A-3120 Hydra-Drive/Slipper shaft. Which means it will also fit the A-3007 JRX-Pro top shaft and the A&L Power Clutch shaft.
I've just done this exactly after I received the topshaft and delrin gear today. However it binds when I tighten the gearbox fully. Did you need to grind any gearbox inner? I notice my Thorp gear is marginally wider than the stock gear for that topshaft.
BattleTrak
Has thanked: 1153 times
Been thanked: 624 times
Post by BattleTrak »
Nige55 wrote: Tue Nov 15, 2022 5:43 pm
No, I didn’t have to grind anything.
A few things to check:
- Make sure the roll pin is centered or not too long to where it is interfering with the gear mesh.
- Make sure the hole for the top shaft in the gear case is 5/16” so that it doesn’t rub the slipper plate.
- Last, be sure to install a shim on the end of the top shaft…#69 in the pic.
-Brad
Nige55
Post by Nige55 »
BattleTrak wrote: Wed Nov 16, 2022 6:30 am
Perfect! Thank you!! I realise from your post I don't have the shim there at the end of the shaft. Thank you, I'll try adding that
Nige55
Post by Nige55 »
Thanks again for the help! Weirdly it's still binding. looking at the metal stock gear on that shaft, it doesn't protrude past the pin (the pin sits in a recess for it), whereas the Thorp one does. So I may just try sanding it down on the pin side.
Return to “Losi Forum”
