Thorp 64 pitch gears - what are the disadvantages
- Has thanked: 1243 times
- Been thanked: 639 times
I have a set of rc10 GT Thorp 64p gears.
They seem like a 1:1 drop in for the stock gears.
Is there a disadvantage to them?
I assume that if they can handle a gas engine than a brushless 2-3s lipo setup wouldn't be an issue.
overall would they simply change the sounds of a truck?
Is there actually an advantage?
- Has thanked: 1129 times
- Been thanked: 3918 times
Re: Thorp 64 pitch gears - what are the disadvantages
more efficient. Note that brushless has immensely more torque than a nitro truck, I wouldn't use them with brushless personally.
- RogueIV
- Has thanked: 2137 times
- Been thanked: 1100 times
What Jeff said. While the brushless might be around the same top speed they are much more aggressive at lower RPMs. Remember electric motors produce 100% of their torque at start up which can decimate 64p gears pretty easily, especially if there's jumps involved.
so basically one slip up with a slipper and they are toast.RogueIV wrote: ↑Tue Jul 02, 2024 9:01 pm What Jeff said. While the brushless might be around the same top speed they are much more aggressive at lower RPMs. Remember electric motors produce 100% of their torque at start up which can decimate 64p gears pretty easily, especially if there's jumps involved.
- Lowgear
- Has thanked: 121 times
- Been thanked: 795 times
I'm not sure if I'm stating obvious information you already know but the higher the numerical pitch, the finer the gear teeth. The finer the gear teeth, the easier it is to strip them. As such, they also aren't as forgiving to debris. The advantage is they run smoother. 64 pitch gears are used extensively on pan cars as they're lightweight so less strain, no jumps, and you only have to worry about carpet fibers.
- RogueIV
Yeah, I wouldn't do it. I'd stick with 48p stuff with offroad and if they are heavier or insanely over powered, 32p.JosephS wrote: ↑Tue Jul 02, 2024 9:13 pmso basically one slip up with a slipper and they are toast.RogueIV wrote: ↑Tue Jul 02, 2024 9:01 pm What Jeff said. While the brushless might be around the same top speed they are much more aggressive at lower RPMs. Remember electric motors produce 100% of their torque at start up which can decimate 64p gears pretty easily, especially if there's jumps involved.
did anyone make 32pitch gearbox internals for the gt or 2.25 stealth?RogueIV wrote: ↑Wed Jul 03, 2024 8:45 amYeah, I wouldn't do it. I'd stick with 48p stuff with offroad and if they are heavier or insanely over powered, 32p.JosephS wrote: ↑Tue Jul 02, 2024 9:13 pmso basically one slip up with a slipper and they are toast.RogueIV wrote: ↑Tue Jul 02, 2024 9:01 pm What Jeff said. While the brushless might be around the same top speed they are much more aggressive at lower RPMs. Remember electric motors produce 100% of their torque at start up which can decimate 64p gears pretty easily, especially if there's jumps involved.
- 1056 Views
Last post by asashaw
- 1010 Views
Last post by OldSchoolGuy
- 2479 Views
Last post by 8valve
- 2607 Views
Last post by Nige55
- 2162 Views
Last post by slow_jun
- 1021 Views
Last post by Brat
- 976 Views
Last post by Optinutz
- 591 Views
Last post by Prince Steve
Users browsing this forum: Rc10812,
timjz,
XLR8 and 6 guests
