Thorp Dirt Burners Hard Final Pinion Gear
I just scored this on the 'Bay...I hope I'm not mistaken, but isn't this comparable to the OT-76 Hard Final Pinion Gear? I confirmed with some searching that it's made out of steel.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rt=nc&nma=true&item=180613025566&si=xaMaBpiUoGBAeFm%252BBaxdYQUY1V4%253D&viewitem=&sspagename=STRK%3AMEWAX%3AIT
Part # 4738 info:
http://www.rcchopshop.com/thorp/thorp_manufacturing_rc_car_parts_list.html
bdrmbully
Re: Thorp Dirt Burners Hard Final Pinion Gear
Post by bdrmbully »
nice final pinion there.
2nd place is just the 1st loser
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
I noticed the wrong header on ebay also. It is for an optima and not optima mid indeed. Only question remaining : is it the correct pitch or is it for use with thorps smaller pitched diff...
Mad Racer
Post by Mad Racer »
I have one too.
I got with a counter gear set all made by Throp/Dirt Burners.
The final pinion is the same as Kyoshos but a little heavier . Better Steel.
Mad Racer wrote:I have one too.
As long as it's better than the craptastic aluminum stock gear, it's all good!
Just a quick confirmation--received the gear today, it's an exact match for the stock OT-41 gear. It's made of steel however, and is significantly heavier than the stock aluminum gear. As OT-76 hard final pinion gears are few and far between (and expensive as heck when you find them), I'm pretty lucky I discovered this Dirt Burners unit!
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarAhrefs [Bot], User avatarSwath and 3 guests
