old -newbie with a rc10 gold pan
- Has thanked: 13 times
Re: old -newbie with a rc10 gold pan
Do you have any recommendations for wheels as the rear spindles are tapered, the guys at hobbytown dont know what to use.... the hex adapters might work but 8ll have to bore them out and the the offset I find in newer wheels is real deep which would run the shocks...
Can you pull the old tires off the wheels? I think they might be 2.2" wheels already.
If not, your easiest source of 2.2" 1/4" axles is from jc racing in the UK. They are a direct fit, a little narrow on the front for modern wide tires but carpet tires fit just right.
Beyond that, you get into axle conversions and other changes.
- Has thanked: 36 times
- Been thanked: 1318 times
For the back you can use....
these hexes: https://www.ebay.com/itm/Factory-Works-Vintage-12mm-Kyosho-Wheel-Adapters-For-1-4-RC10-Axles/303028873957?hash=item468dedaae5:g:qM4AAOSwjPdZ2WeO:sc:USPSFirstClass!18067!US!-1:rk:27:pf:0
these wheels: https://www.ebay.com/itm/Traxxas-7171-Wheels-Dished-2-2-inch-White-2/401682987104?epid=1337772845&hash=item5d862bf860:g:f0YAAOSwDEBcNnR7:rk:1:pf:0
What about the fronts to match?scr8p wrote: ↑Thu Jan 24, 2019 9:02 am For the back you can use....
I found some hex adapters, but need to drill out centers.
Yeah they are 2.2 tires, I just dont like the rims, they are like polystyrene or something.. I'll look into jc racingjwscab wrote: ↑Thu Jan 24, 2019 8:06 am Can you pull the old tires off the wheels? I think they might be 2.2" wheels already.
If you use narrow carpet tires, and trim off the inner bead of b4 front wheels and they will drop right on (bearing wheels)
- 693 Views
Last post by Sito12345
- 1627 Views
Last post by juicedcoupe
- 2460 Views
Last post by Lonestar
- 1000 Views
Last post by JosephS
- 33 Replies
- 3913 Views
- 1834 Views
Last post by smurf420
- 5008 Views
- 1704 Views
Last post by rawpwr
