RC10 gold pan
michiganionia
Has thanked: 7 times
RC10 gold pan
Post by michiganionia »
I changed out the rear suspension mounts because one was cracked, when I took the old ones out I noticed somebody had cut them down, why would they do that?
Also does anybody know what these black rims are? I striped one of them out and I bought some new ones from j concepts but they rub on the shock tower.
helbnd1
Has thanked: 226 times
Been thanked: 22 times
Re: RC10 gold pan
Post by helbnd1 »
I can't see from the pictures of the wheel that well, but they're possibly b4 wheels. Rubbing where the lower shock mount attaches to the a-arm, correct?
The front hole of the suspension mount was probably cut off to run the short wheelbase location without having to notch the original bulkhead.
michiganionia
Re: RC10 gold pan
yes that's where its rubbing, what wheels will work?
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Re: RC10 gold pan
Post by JosephS »
michiganionia wrote: Tue Aug 09, 2022 12:01 am yes that's where its rubbing, what wheels will work?
J- CONCEPT mono wheels might work https://www.amainhobbies.com/jconcepts-mono-2.2-rear-wheels-white-4-rc10-jco3404w/p1157761
can you take off the wheel and show the axle that it is attached to?
Has thanked: 269 times
Been thanked: 2095 times
Re: RC10 gold pan
Does that car have rear hex conversion?
If so, use Traxxas 7171 wheels.
JosephS
Re: RC10 gold pan
Post by JosephS »
juicedcoupe wrote: Tue Aug 09, 2022 5:27 am Does that car have rear hex conversion?
That's why I was curious about the axle picture. For rears with the 3/16 axle it seems easy enough to switch from hex to pins by putting the hex in the wheel.
