Getting an old abused car running again.
Jimbo302
Has thanked: 14 times
Re: Getting an old abused car running again.
Post by Jimbo302 »
Looks like the steering controller arm has had it. Will I have to replace the whole box?
THUNDERSTRIKE1
Post by THUNDERSTRIKE1 »
SERVO IS USAUALLY FINE.Put another arm on it and roatate by hand or with radio and use hand put resistence on it see if servo gears are stripped.But most time just needs new servo saver arm or plain arm depending on vehicle its in.DON
Jimbo302
Post by Jimbo302 »
The grease is proving difficult to remove. I remember the can said "lithium grease", and I sprayed it on moving parts.
Stuff is still grease after 25 years, ha.
I got most of it off the front suspension here.
I'm going to remove the rest of the sway bar as well. It looks like I will need one of the ball mounts to replace the missing upper arm.
Jimbo302
Post by Jimbo302 »
THUNDERSTRIKE1 wrote:SERVO IS USAUALLY FINE.Put another arm on it and roatate by hand or with radio and use hand put resistence on it see if servo gears are stripped.But most time just needs new servo saver arm or plain arm depending on vehicle its in.DON
Yes, the servo is still good, I was curious if just a replacement arm was available somewhere or if I had to purchase an entire unit.
R Cane
Has thanked: 159 times
Been thanked: 64 times
Post by R Cane »
Looks much better already.
Sure, you can just buy a little servo arm pack without the servo. They often come in a pack with several, to fit Futaba, Airtronics, or JR servos (different splines)...yours is obviously a Futaba, so just make sure that's what you're getting.
After sitting so long, I'd certainly get a shock rebuild kit too, especially if you plan to run it.
Jimbo302
Post by Jimbo302 »
The ball joint for the sway bar is not the same thread as the one for the upper arm. So there goes that idea. Maybe I can find some hardware kits with these pieces.
R Cane
Post by R Cane »
Looks like you are missing the #6270 ball end from the top of the carrier. Same as the ones in this pack...
http://www.ebay.com/itm/Associated-RC10-GT-B3-T3-Ball-Joints-One-Pair-/371607961605?hash=item56858f8005:g:nOcAAOSw9uFW9CHh
As I recall, that one threads into the carrier. If that hole is stripped out, you'll need a new carrier or a ball end with a longer shaft so you can put a nut on the back.
R Cane
Post by R Cane »
Do you still have the manual?
Jimbo302
Post by Jimbo302 »
You are correct, it does thread in. The threads still appear good, although it would be nice to have a longer stud for a backup nut.
I do still have the manual, yes.
Jimbo302
Post by Jimbo302 »
A few new electrical connections.
Jimbo302
Post by Jimbo302 »
R Cane wrote:Looks like you are missing the #6270 ball end from the top of the carrier. Same as the ones in this pack...
Okay, so I bought that kit and a ". Hot Bodies HB Aluminum Steering Servo Horn ". Now I need to find a rod to replace the missing one.
Jimbo302
Post by Jimbo302 »
Okay so I eliminated all the extra three wire plug and radio wiring since the car has always run the remote servo power on a 9v. I bought this to replace the original switch and plug.
Jimbo302
Post by Jimbo302 »
As for the shocks, I think I will oil them and see how they do. If I remember it came with a little oil supply for them originally, what is a good oil to use?
Jimbo302
Post by Jimbo302 »
Looking on eBay, would a world car turnbuckle setup fit this car?
Also I'm looking on https://www.teamassociated.com/
What model rc10 should I be looking for parts under?
Also what bodies fit this car?
Been thanked: 498 times
the rc10 classic will supply you with the closest replacement parts.
also, 20w-30w oil is around the right range for the shocks, the kit usually supplied 30w.
Users browsing this forum: No User AvatarAmazon [Bot], No User AvatarBing [Bot] and 10 guests
