Best way to punch holes in lexan
- bully
- Been thanked: 6 times
Re: Best way to punch holes in lexan
I use the duratrax one and surprising it's actually very good. +1 on the dubro it's blunt as
- Has thanked: 100 times
- Been thanked: 205 times
Oddly I tend to do something similar, Using a standard fine point Weller 25watt soldering iron I let it heat up and then.. boom, hole. The excess melted lexan pops right off with a quick swipe of an xacto or a single edge razor blade.Nobby Sideways wrote:Please be aware I am a novice....
When I needed a hole for my body pin I used a teaspoon with a perfectly round handle, heated it over the gas stove flame and just pushed it through. It has the advantage that it quite neatly adds a little extra thickness at the hole edge which gives it additional strength as some of the plastic moves aside rather than just sticking to the spoon. It sounds messy but its really quite simple and gives an elegant hole. You can see it in the picture below (sorry I don't have a better one, its the hole at the nose).
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- 21 Replies
- 2448 Views
Last post by uzzi
- 938 Views
Last post by SteveK
- 3112 Views
Last post by MelvinsArmy
- 830 Views
Last post by RogueIV
- 743 Views
- 1628 Views
Last post by tomolupus
- 2171 Views
Last post by mick355
- 699 Views
Last post by CUDDZILLA
Users browsing this forum: Google Feedfetcher and 4 guests
